Oled lg 55ec930v
    Re: Oled lg 55ec930v
    blocking randomly? which is the tcon model?
      This type Davi borrowed from eBay as the tv is all done up for now thanks for your help
        Hope this helps
          i have to gather one better picture and an android sw for editing it
            Can I help what do you need a photo off please Davi
              i was ensuring you were blocking the right traces..
                Ok thanks awaiting your advice thanks again
                  Those stupid Android programmers, there isn't any that programmed a landscape view photo editor..
                    Oh dear see what you can do I appreciate everything you do thanks
                      The traces to block are the group on 1 or on 2 , it is impossible to know without to try.. but this on the faulty side..
                        By blocking traces with tape the controller "thinks" there is a mistake and the t-con will go in protection. An Oled t-con works much different that a LED t-con.
                          Thanks I will give it a go Davi thanks again my friend
                            Oh I see mmmm what to do now lol
                              (Just a quick update) Well a bit of a change it’s starting to flicker now without any clk lines blocked the top 3 quarters darker shading disappeared for an hour then when I moved it it can back cleaned lvds cables with proper cleaner still flickers every no and then and sometimes I move the screen and it clears to a perfect picture
                              Thanks to Davi and William1967 for the advice and help so far
                                Here is the screen when the top half has cleared
                                  Maybe a defect of a connection within the panel like it happens on lcd tv, but need to know how are made these panels, if there are cof tabs on the side of them, in lcd world we can add a thin wire to rebuild the connection..
                                    You could be right there Davi thanks for your help 😁
                                      Looks like failed gate driver on left side. You are only getting half the resolution in that section. Maybe disable VGH on that side to even out the resolution.
                                        any one talking on blocking feed line on OLED panel mean he never had oled one under his hand.. so don't play with it any more..
                                        there are resistances record saved automatically at the T-CON eeprom firmware, registered the working hour and view setting condition beside the charge and discharge of the Micro Leds. it mean if one line (pixel Line ) get out of order doesn't mean always its total Panel fault.
                                        IN_STOP command or downgrade then upgrade firmware will help too. be caution OLED Panel should never never never disconnected from T-CON at any case. then you will have more line and distribution at picture.
                                          Hi guys moved it on now it was very intermittent
                                          Just waiting for a tcon for the second one now same model but has banding on the screen which I gather is common
                                          Thanks again guys
