i have no backlight this probleme only whileusing the laptop on the battery power and when i plug 19v charger the light come on i all ready change the battery
no backlight asus x55ld
Re: no backlight asus x55ld
More clues will be helpful.
1) Correct model # is Asus X555LD ?
2) When on battery, does the laptop boot ? Can you see the graphics with the HDMI port & external monitor ?
Or is the fault that the laptop does not work at all on battery ?
3) When on battery, what are the results of the flashlight test ?
2yes the laptop boot normaly the only problem is theres no backlight on the screen
3 when i power the patop on battery is start normal and boot up but no backlight but when i plug thr charger in the light come on
Originally posted by mon2 View PostWhat is the model of your logic board ?
See attached.
No schematics available but we may have boardview files.
Do you have a multimeter & hot air soldering tools ?
