Hi guys
I have this faulty mixer here. Basically the owner says it worked fine at one gig, then the next one it didn't
When I power on, both the L & R LED Meters go to +4 and stay there. This is without any input and with all sliders Level Set knobs set to zero
Also the LED meter on the 24-bit dual engine DSP goes to red (clip)
I didn't connect an speakers but if I use headphones I can hear what I can best describe as a purring noise on both channels
I found a schematic for the PSU There is a 10 way ribbon cable going from the PA/PSU to the mixer section.
According to the schematic I should have on this cable, from the left hand side:
Ground
Right Audio
Ground
Left Audio
+ 15V (red wire) - reads 14.79V
- 15V - reads 15.25V
Ground
+ 48V - reads 46.6V
+ 5V - reads 4.88V
I tried connecting an audio source to Channel 9/10. I ca nsee the rare some 8 pin chips on each input channel (see pics) these are marked 4580 and I found a datasheet that says this is a dual op-amp
With my scope I can trace the audio signal on each output pin of the op-amp chips, up to the row of chips at the top of the PCB (under where the channel numbers are marked on the silk screen - 1,2,3.....9/10, 11/12
I am getting audio signal as far as here but I don't know where to check after that. I still get the purring noise on the headphones and can't hear the audio signal at all
There is no audio signal on the 10 way connector feeding to the PA.
Any suggestions where to check next, and does anyone have a schematic for the mixer PCB.
Rich
Ground
Right Audio
Ground
Left Audio
Ground
+ 48V - reads 46.6V
+ 5V - reads 4.88V
Rich
