equivalent FSD210
    equivalent FSD210
    Hi does the ic FSD210 power switch have pin to pin equivalents?
    Thanks for the reply
    Re: equivalent FSD210
    Equivalent to what device ?
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      I meant if it has an equivalent with a different but replaceable abbreviation
        When ever you have this type of device you really should use the exact same part number because the switching power supply transformer is is made for it
        9 PC LCD Monitor
        1 Dell Mother Board
          A quick google search comes up with these that MIGHT be similar. You will need to check the datasheets.
          I take NO Responsibility if these do not work.
          Similar parts: ICE3BR4765J, NCP1052B, TEA1520P, TNY254P, TNY264P
