Dell inspiron no display LA-9104P
    VAW00 LA-9104P
    board with cpu on board
    This Laptop has no display only beeps.
    after cheking coils found PL700 power is not there.
    Re: Dell inspiron no display
    How many beeps?
      continuesly .its actualy sorry to tell you its not beep a type of tek tek sparking sound comming from speaker.
      every 2-3seconds
        maybe schematics helps
        Im Back... sort of...
          when i switched on +3valw & +5valw is ok but +3vs & +5vs & susp# voltage on qz8 is less then normal please any one master can solve the problem stub by stub
            every 2-3seconds
            Dell 3521 tuk tuk sound is definitely bios problem.Flash both 2mb and 4mb bios and it will solve your problem.May need to remove cmos once.
              i .Flash both 2mb and 4mb bios and it will not solve the problem
                  Flash SIO ( KB chip ). It will resolve your problem.
                    i change SIO and Flash SIO ( KB chip )and change pch will not solve the problem
                      VAW00 LA-9104P
                      change Crystal, in boardview (YH2)
