This Sony home cinema doesn't want to turn on. It keeps blinking the red standby LED when trying to turn it on.
I've given a chance to ESR meter on power supply and only C914 (47uF/35V) and C901 (4.7uF/50V) show abnormaly high ESR (larger than 50Ω). The first one is the Vcc filter cap for primary switching regulator IC (SanKen STR-F6267), so looks promising. These caps are close to IC heatsink, they suffer a lot.
I change both and done!
After searching (adding C914 to search terms) I found that other Sony home cinemas sharing this PSU (or PSU design) will fail the same way: DAV-S550 (HCD-S550), DAV-C770 (HCD-C770), DAV-C990 (HCD-C990). Maybe others.
