Lenovo T450 BIOS password Dump
    Re: build a new bios from exe file
    No no need just wait a seconds
      with this error i am not able to enter in to the bios
        Resolder your bios chip, be careful about resistance/caps near his legs
        can you post a picture of the bios chip soldered on motherboard !
          Thanks martha februarini & lapfix For your kind support
          solved by rebuild new bios region in bios section and flash that in same chip
          it means there was no administrator password
          but i try 3 bios from online like vinafix and all there was no display
          so i have hope only from the original backup only
          and finally job has done
            Need help recovering Lenovo ThinkPad T450 's bios
            Hello! I am wondering if its possible to make my Lenovo T450 work again. The problem is - I tried to flash the bios and remove the administrator bios password but made a terrible mistake -
            I used a CH341A Programmer with it's official Windows software. But turns out this software has a bug and can't correctly work with "W25Q128.V" chip. It fails to correctly read from and write to a chip. Which was also noticed by a user "Weelcup"
            So I used this program and, of course, I didn't succeed. Not only it failed to correctly write, but the ORIGINAL dump is also corrupted now and doesn't work when I try to flash it back.
            I made multiple copies of the original dump and they all differ from one another - I noticed it before writing to a chip but failed to realize I would need the original dump again...
            Later, I decided to install Ubuntu and use flashrom instead of the official software on a second identical T450 I have (thanks for this advice to a user "mockingbird" in a previously mentioned thread).
            Everything went perfectly on the second laptop, using LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal I successfully patched the bios and restored the original - admin password is gone.
            But the bios from the second laptop doesn't work on the first one. I also tried a couple of bios dumps I found on this forum none of which has worked.
            • Laptop turns on - no image - shuts off in a couple of seconds.
            • Or, turns on - no image - beeps 5 times - shuts off..
            I guess I need to restore the original but I am new to all of this and don't have a clue on how I can restore it from this state.
            So, If anyone have any ideas I would greatly appreciate your help!
            I will attach corrupted readings of the original bios dump.
            Chip is "W25Q128.V"
              lenovo t450 bios password
              hey can any one help me with this bios
                Re: lenovo t450 bios password
                STEP 1: Flash and replace current BIOS with the generated patch file
                STEP 2: Boot the machine
                STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                STEP 4: Enter any character when asked for Supervisor Password
                STEP 5: Press enter when it shows Hardware ID
                STEP 6: Press space bar 2x when asked
                STEP 7: Turn off machine
                STEP 8: Restore original BIOS
                STEP 9: Reset BIOS settings to factory default
                  east or west and you ar the best thx
                    please i need t450 patched
                      Become a Badcaps supporter
                      Thanks to all supporters.​
                        Re: Lenovo T450 BIOS password Dump
                        thanks a lot for the bios patch its work.
                        can i have this one too please.
                          Here you are
                            anybody give me patch file?
                              hello guys help me find a bios dump lenovo thinkpad t450 cpu i5 20bv-001us I can't help but how it will start after an unsuccessful firmware and the dump that I thought was probably not correctly considered!
                                PASSWORD lenovo need patch T450
                                NM-A251
                                  Re: PASSWORD lenovo need patch T450
                                  NM-A251
                                  did you search the forum ??
                                    NM-A251
                                    Try this
                                      can anybody help me patching this dump... bios pass
                                        Originally posted by Artyom92 View Post
                                        hello guys help me find a bios dump lenovo thinkpad t450 cpu i5 20bv-001us I can’t help but how it will start after an unsuccessful firmware and the dump that I thought was probably not correctly considered!
                                        Have you tried using the Autopatcher at post #1 here https://www.badcaps.net/forum/showthread.php?t=87588 and following the instructions ? ,everything you need is there.
                                          am running windows 7 32bit so python 3 failing to install
