iPhone XS not charging
    The cables and lighting port chargers did not help.
    Current consumption from the charger is 0,00A
    PC not reconize Iphone
    Iphone work if have battery is charged.
    I found short circuit on the lighting flex socket of the motherboard on pin 14 (PMU_TO_PHALANX2) and pin 17 (PMU_TO_PHALANX1).
    And pin 20 (MIKEYBUS_REFERENCE) 100 Ω.
    pin 24 (90_HYDRA_DP2_CONN_P ) pin 26 (90_HYDRA_DP2_CONN_N) pin 28 (90_HYDRA_DP1_CONN_P) and 30 (90_HYDRA_DP1_CONN_N) its OK
    Need replace U2700 ?
    Re: iPhone XS not charging
    You need to change the chargings coils.
    Good luck
      Which coils?
      FL6411 and FL6413?
        Pin 14 and 17 on J6400 are ground pin it's not a short.
        Connect a charger and check PP_VBUS1_E75 (TP0773) you should have 5V.
        If it's ok you have to separate the motherboard and check value in diode mode around U3300.
          Where found TP0773? with part pcp?
          I dont have soft only pdf
            You can use phoneboard for boardview is free programma. Sorry i was mistake the chargingcoils is for iphone x probably hydra ic need to be replaced i think.
            https://phoneboard.co/
              I have 5V on B242.
              Need 100% separate to continue ? or maybe U6300 (hydra) change?
                no, this is a blind way.
                Desolder a sandwich and check again everything from PP_BAT way to VDD_Main. You have to have a some schematic diagram, boardview should be enough.
