Sony KD-55XF8505 won‘t start
    Does anyone have the service manuel for the KD-55XF8505?
    I've already tested a few things and apparently the mainboard is defective and I don't have the exact instructions on how to find out what's defective.
    PSU and T-Con seems to work.
    Re: Sony KD-55XF8505 won‘t start
    Better 4 you to explain all symptoms, measurements done...
      Wow, to have mainboard schematics. That would be awesome.
        When I plug in the TV, everything stays black, the status LED also stays off.
        PFC: 390V
        CN6801-2-3-4-5: 75V
        CN6401-5 (STBY3.3V): 3.5V
        CN6401-8 (BL_ERR): 2.3V
        CN6401-13 (REG12V): 12.7V
        CN6401-25 (TCON_VCC12V): 0V
        At the Mainboard (for example at the ICs at the top) there is 3.5V present and also at the wifi board.
        When I try to turn on the TV with the power button or with the remote control, nothing changes.
        Next I checked following:
        CN6401-7 (BL_ON) connected with 3.3V:
        The relay on the PSU clicks and switches
        CN6401-26 (TCON_ON) connected with 3.3V:
        12.7V at T-CON board but no change on panel.
        CN6401-26 (TCON_ON) connected with 3.3V and ribons between mainboard and t-con-board removed:
        12V at T-CON board and the panel changes brigthnes/color. Looks like green <-> black?!
          check if there is a microcontroller on main board for example called PICxxxxxx, i see it probably neat the green audio jack con., it must to be rewritten, have you got an eprom programmer?
            No there isnt any called PICxxxxxx :/
            I attached some pictures.
            And yes i own an EPROM programmer
              what's the marking of IC4001? are there any other spi flash like the 2 you photographed? Is there any IC on the under side of the board?
                Sony often put fuses for protection under the designation Fxxx, there are a lot of them on the board, you need to check them all with a multimeter, and the firmware is in the eMMC (IC2001).
                  IC4001:
                  Sony CXD4760GG
                  S7NC5S2
                  1826
                  Under the board there isnt anything.
                  And no, I think there only this 2 winbond 25Q16 chips with the flash memory
                    so ic4002 probably stores the stby firmware (i don't comprehend what is PiG) and must be rewritten, try desolder it, freeze it on the programmer and soon read it, then save dump and rewrite it on the same eprom, if it doesn't work another possibilty is there..
                      I tested the fuses and none seems to be faulty.
                      In the picture I highlighted every tested fuse
                        Stupid question:
                        What is the dumping and re-rewriting with the same dump supposed to do? If the chip is defective or no longer holds the correct data, then nothing changes with a new flashing of it, right?
                        And PiQ maybe stands for:
                        Prefetch Input Queue
                          Yes IC2001 is the eMMC (Samsung KLMAG1JETD-B041).
                          But could it be, that the firmware is faulty?
                          And if so, how could I test or fix this?
                            It is not the same reading normally the eprom and reading after freezing
                              Yes, there may be a problem in it, the bootloader is located in it, only the EMMC programmer and a known working dump for this chassis will help here.
                                Briefly summarized:
                                So we all assume that the motherboard is defective and nothing else, right?
                                I have already ordered a used, tested mainboard (which I could send back, if i could find the problem with mine).
                                If it's the eMMC, then I can't get any further without a dump and programmer anyway, and unfortunately I couldn't find anything here in the forum or on google.
                                And I could still do that with the eeproms, but I'm wondering if it's worth the effort, since I almost don't assume that it's their fault?!
                                Theoretically, if the other board is delivered, I could also dump the eeproms from this board (using a clip) and then flash them again at my old board.
                                  Most likely they (SPI Flash) refer to T-Con, (settings for different matrices).
                                    I also assume that the fault is not there, since the TV shows no reaction at all. Or did I misunderstand you?
                                    For me as a layman it really sounds more like the bootloader. And is that also correct, if something doesn't fit there, the CN6401-8 (BL_ERR) just doesn't deliver 0V but like at my point 2.3V
                                      Try to make a hard reset by pressing the buttons and connecting to the power supply.
                                        Unfortunately, I've tried that before, but without success
