Acer Aspire 4745g power problem
    Good day to everyone. I've got an acer aspire 4745g laptop which turns on then off again in just under 1 sec. When I press the power button the power led blink once then off and there is no sign of life. I need to unplug the power adapter to make the power led light again. I've tested the adapter and its ok. Power jack and its wire are ok because voltage are present on the motherboard.
    Motherboard receives 19.5v. Are there any areas I need to check regarding power. I also checked the motherboard for burnt components and I see none. I also got the schematic diagram for its board. Hope someone helps. thanks!
    Re: Acer Aspire 4745g power problem
    check for 5v 3.3v alw
    saw the schematic, check PL15 5V, PL16 3V
      thanks for the reply. checked 5v on RT8206B pin no.14 (en1) OK and 3.3v on pin no.27 (en2) OK. 5v on PL15 is 5.14v and 3v on PL16 is 3.29v. Is this ok? I also measured sw1 3.3v when pressed becomes 0.5v.
        check pq63,64,65 and 66
          thanks again. pq63 and pq64 5.18v is present, pq 65 and pq66 3.38v is also present. where else do I need to check?
            Voltage on PL11, PL12, PL9, PL17, PL14, PL7, PL13?
              check V on U40 ( W25Q32BVSSIG )
                good day, @ whaldsz all the components you have mention pl7 ,pl9, pl11 ,pl12, pl13, pl14 and pl17 have 0v reading. Is that bad? thanks
                @ dj 0v on pin no 8 on u40. thanks
                  Then check the resistance to ground of those coils and mosfets too.
                    pin 8 on U40 its VDD and it shows +3V .
                    did you check with power on or off?
                    do you have tools to remove it? atleast a soldering iron.
                      ok sir whaldsz Im on it.
                      @ sir dj, I dont have the chance to measure u40 with power because it won't turn on. Yes I do have the tools to remove it. Is u40 the bios chip?
                      thanks again to both of you!
                        Yes thats bios chip. remove it and see if power its restore.
                        without bios it will not Power up but you can see if power led its stable and the battery its charging.
                          @dj or you mean U29 (SPI Flash)? pin 8 of U40 comes from +3V (controlled by MAIND) and would not turn on unless power button is pressed.
                            go on page 44 and try to find some V like the P channel fets and that isl.
                            can you reflow the board? did you try?
                              @whaldsz, the resistance to ground of all mentioned components are ok, low resistance. u29 pin no.8 has 3.38v reading
                              @ dj, haven't done any reflows on the board but I do have a hotair station just incase.
                              I've been reading a lot of forums regarding this laptop and the usual problem involves the gpu. I hope that is not case. thanks again.
                                you need to reflow but make a bottom heater to not just from top.
                                or you can do from top ( a light reflow) just to see if anything change.
                                  Before I reflow anything, I'll be redoing every test on all components just to make sure that I haven't overlooked any readings.
                                  This is what I got on u29 pins (ISL88731A)
                                  pin 11 (vddsmb) = 3.3v
                                  pin 26 (vcc) = 5.18v
                                  pin 22 (dcin) =18.87v
                                  pin 02 (acin) = 4.02v
                                  are these voltages relevant to my problem? Thanks again!
                                    What is the lowest resistance did you measure?
                                      13.9ohm on PL7 why?
                                        i think not. you mentioned in your post #4 that you already have 3.3V and 5V.
