Hp elitebook 840 g5 bios password
    Re: Hp ellİtebook 840 g5 bios password
    serial no
      Serial Number : 5CG907304N
      Product Number : 2FA66AV
      Description : HP EliteBook 840 G5
      Build Id : 17WWCSBT602#SABF#DABF
      FEATUREBYTE : 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfA hKhkjh.GF
      my CT number is : PGWHT00WBBW7RW
      help me please
        help me please
        This is still under warranty.
        I don't provide help for people using CH341A and a clip.
          i live far from where i by this pc... how can i contact them !
            Re: Bios elitebook 840 g5
            Originally posted by tsitsi View Post
            thx, but i solved with bios from internet
            can u give me bios from website...
            thanks
              anyone help me please
                Try
                Become a Badcaps supporter
                Thanks to all supporters.
                  no desplay and fan speed what can i do please
                    Post your mainboard number.
                      6050a2945601-mb-a01
                        Originally posted by peste View Post
                        post both bios .. preferably the original ones..I hope you made a copy ??
                        @Peste could you help me with the matter I spoke to you about last month I did post the original ones as in quoted link
                          [/ATTACH]
                          my dump 32b is impty
                            Try these ones
                            https://www.badcaps.net/forum/showpo...83&postcount=2
                            OR if not work
                            https://www.badcaps.net/forum/showpo...09&postcount=9
                              Originally posted by Vesko356 View Post
                              You're kidding right?
                              G5 series are Sure Start equipped machines, so either MPM mode must be enabled in the main bios, or nvram section of the EC chip must be edited. Editing only usercred section on main dump will not be enough for sure.
                              All G5 line are HP Sure Start equipped (HP Sure Start Gen4 if they are shipped with Intel 8th generation processor onboard), otherwise HP Sure Start Gen3 (7th gen Intel onboard). So again - there's no way to remove the password on these with simple usercred section editing. I've sent the edited MPM enabled dump to the guy, that's why the problem was solved.
                              This is also true for the case when the HP BCU shows an attachment?
                                Hi.
                                There is an HP EliteBook 840 G5 with a BIOS password. There is also a programmer, an adapter and a chip. 3.3V is set on the programmer, everything works - it was read / erased / written / checked several times. I'm waiting for another chip and a probe (yes, I read on the forum that it's better to solder the chip). Perhaps important HP BCU considered:
                                Sure Start BIOS Settings Protection
                                *disable
                                enable
                                Have questions:
                                1. The status of computrace is not yet known. Suppose it is active, in which case which of the dumps needs to be modified by the BIOS or/and EC ?
                                - BIOS HPunloker + BIOS HxD (computrace 3F --> 3C)
                                - BIOS HxD (computrace 3F --> 3C) + EC RCUnloker
                                - EC RCUnloker + BIOS security reset on first boot
                                2. If I use a probe, then turn off all the power or leave something connected in a special way?
                                RethoricalCheese, can you explain the nuances for the HP EliteBook
                                3. Do I need to reinstall the operating system after the modification?
                                Thank you.
                                p.s. please forgive me for detailed questions, but I don't want to get a non-working device and have backups on original chips
                                  Originally posted by NaneName View Post
                                  Hi.
                                  *disable
                                  enable
                                  Have questions:
                                  Thank you.
                                  BIOS HPunloker + BIOS HxD (computrace 3F -> 3C)
                                    Notebook displays "Protected by HP Sure Start" under the HP logo while booting.
                                    After loading the operating system, the BCU shows options:
                                    *disable
                                    enable
                                    HP Sure Run Current State
                                    Inactive
                                    Sure Start Secure Boot Keys Protection
                                    Disable
                                    *Enable
                                    SureStart Production Mode
                                    Disable
                                    *Enable
                                    After modifying the main BIOS on the first boot, will it be possible to enter the BIOS to reset the security?
                                    And yet, there is no identifier in AbtState, but Asset Tracking Number = Serial Number.
                                    Do I need BIOS HxD (3F --> 3C) in this case or not?
                                      Re: Hp ellİtebook 840 g5 bİos password
                                      Remove tha pasword 830g5
                                      and how? reply me thankss
                                        Try
                                          Hi all!
                                          Probe delivered. But the situation is bad. All 5 readings gave different results.
                                          The situation by region is in the attachment.
                                          "+" - match
                                          "-" - difference
                                          Is the 3rd reading correct? For flashing, the chip will be soldered.
