This Pioneer Kuro KRP-500 plasma display has an intermittent issue in that it the picture turns black suddenly.
Sound works all the time.
Powerled is on all the time.
This set has a separate control box which for a few years had a similair problem which was fixed by replacing a number of voltage regulators.
Quite a common issue as fas as I know.
Question is: are there more of the notorius voltage regulators also inside the display unit which should be replaced?
Other advice?
There are not a common cause which makes the issue. Can work for two days, or 30 minutes.
Then a powercycle is needed (of the display unit) not the controlbox in order to make it start up picture again.
Other advice?
