Bought the TV about a month ago faulty as it would take about an hour to turn on turns out it was the tcon board as with a reflow has been working great for a month but now the problem is returning upon looking for a replacement there are none on the Internet looked everywhere the only board I can find close is for a 55fx700b which has the same sub model which is a 6870C-0757A but a different main part number mine is a 6871L-5491A and the one for the 55fx700b is a 6871l-5478h anyone had any joy in swapping theses or repaired the original board any help would be appreciated
Panasonic 65fx700b intermittent tcon problem
Re: Panasonic 65fx700b intermittent tcon problem
Finally managed to sort this if anyone has the same problem you order a tcon for the 55fx700b 6871l-5478a and your remove 2 sets of caps from the board will put the numbers up tomorrow then use a ch341 programmer to read the epprom of the previous 5491a board and flash it to the new board or just do a chip swap with 24a32 epprom on the board. Now the TV runs great known issues with this model of TV and the tcons are near impossible to get hold of
For those that think a reball is always the answer AND don't presume to tell me you know MORE than Louis Rossman: https://www.youtube.com/watch?v=1AcEt073UdsLast edited by nomoresonys; 04-27-2020, 02:28 AM.
Originally posted by nomoresonys View PostFor those that think a reball is always the answer AND don't presume to tell me you know MORE than Louis Rossman: https://www.youtube.com/watch?v=1AcEt073Uds
Originally posted by nomoresonys View PostYou are WEAK, as is your arguments, It is a very good thing that you did not become a defense attorney, they are bga chips, the end.
As far as I am aware he doesn't repair TVs or consoles that have all suffered from cracked solder joints of the BGAs due to repeated thermal cycling or from tin whiskers causing a short. Occasionally the chips do die, probably from heat but the majority have been fixed with reflowing or reballing.
It's not Nvidia chips exclusively BUT I didn't think you would grasp that EITHER and they die a lot more than occasionally, that's why reballing and reflows are not working per your bad advise in this case, which the chip wasn't even the problem.Last edited by nomoresonys; 04-27-2020, 12:32 PM.
Originally posted by nomoresonys View PostIt's not Nvidia chips exclusively BUT I didn't think you would grasp that EITHER and they die a lot more than occasionally, that's why reballing and reflows are not working per your bad advise in this case, which the chip wasn't even the problem.
I'm not sure how you can clam it wasn't even the problem in this case, OP did a reflow that lasted a short while, I'm guessing it wasn't a very good one (no offence OP).
Originally posted by nomoresonys View PostIf you had average reading comprehension dif, then you would have gathered that it was an eeprom problem that the OP solved.
You can both agree to disagree. Leave it at that !!!!!!!
Originally posted by SMDFlea View PostYou can both agree to disagree. Leave it at that !!!!!!!<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Can confirm the problem was with the dc-dc ic part number sw50212 but couldn't source one it would only work when heated so was failing not the solder so to fix I got a working board off a 55inch and did an epprom swap and removed some capacitors hope this helps people with the same problem
