intergrated tcon board ic rt6939 vestel polaroid p55up0277a
    Re: intergrated tcon board ic rt6939 vestel polaroid p55up0277a
    for this cheap sets / mainboards don't have extra video processing ICs also usually all signal come from Main IC direct via LVDS to the panel.
    if you could upload focused photos on the main boards and the LVDS sockets from up and down side if there any remark on the pins.
      Originally posted by jimbofz View Post
      hi did you trace the source of the enable voltage from the main board? as Diah
      sugested ?
      ive studied the circuit and cant see where the enable comes from
      can you help? thanks
      Diah misunderstands me. Your panel is short circuited. I replace this ic but still not working. I send tv to panel repair workplace and they replace cofs.
      https://yadi.sk/i/_6VKMJQ4rQYiAA This is circuit diagram of mb120.
      https://www.badcaps.net
        i see,,, so you have DC to DC correct working before replace COF.
        the signal which come from main boards via R440 100R connect to lvds socket pin30
          heres the pics ,
          ive studied cct vbyone/lvds options
          and found r440 shown as : L dim en pin 22
          on the main board socket for lvds pin 22 is earth
          and pin 30 doesnt appear to have any connections to it ?
          after removing main board and tracing pin 30 ?
          i must be missing something
            i didnt realise that it was possible to replace cofs
              heres the pics ,
              could you locate on boards the U12 the MFC SPI 4Mb ?
                this set had 2 SPI U13 for MBOOT. at your case its function... and the other U12 for MFC this is i do suspected.. MFC the displaying of picture.. normally the SW of vestel before we do have 3 parts 1-MBOOT.bin 2-MFC.bin & 3-opertion firmware. if MFC corrupted no display as yours condition.
                  on my 17mb120 theres a u11 and a u13 ,but no u 12?
                  but on the circuit diagram u 12 ie shown.
                    Yes. Tvs all functions working correctly jus missing same panel pcb voltages.
                      are you sure ? on the downside did you check too.. look on number of it in schematic and look after all SPI with 8 pins
                        U12 is spi of U14. Your chassis have single lvds option and don't have U14.
                        I insist on cof failure.
                          arizanotlari... the schematic you upload here are for ONE CHANNEL LVDS. as the set of OP. MFC SPI U13 not U14..
                          do you have recovery firmware of this set with 3 files???
                          i have MFC.bin used by vestel such 246009 & 240226 which used over most vestel.
                            if you check page 14 of document you can see 1&2 lvds options. U13 is Mboot SPI not MFC.
                            U14 is position code of MFC ic.
                            Vestel dont allow access to firmware of export products. I have full firmware of
                            QNDS2DN12 panel : https://yadi.sk/d/QyY2xVD8ghxQYw
                            all my respect.
                              sorry been away from pc .
                              does the last post from arizanotlari contain the correct firmware for my tv?
                              if yes can i install this via usb ,
                              considering i have no on screen graphics to enter correct menu
                              my panel type:ves550qnds 2d u12
                                are you sure this label related to Panel Type ? not BL strings Type?
                                  this is the label from inside tv
                                    okay.. i am little confused.. where are yours MFC SPI ?
                                    can you tell how many SPI you have on boards .. 8pins with label No had part on it 25L ?
                                      here are some pics of main board hope it helps thanks
                                        good work... so U11 yours MFC SPI.. do you have programmer CH341A ?
                                          sorry i do not have a CH341A ,
                                          should i put it on my Christmas list?
