need bios dump dell 7480
    plz i need bios dump for this dell motherboard caz20 la-e132p A01 i have erased the bios chip
    Re: need bios dump dell 7480
    i have try 2 dump no way
      Use search option, it's not so hard.
      https://www.badcaps.net/forum/showpo...7&postcount=15
      Become a Badcaps supporter
      Thanks to all supporters.​
        ok bro i will try these ,tanks
          you hae posted two bios chip, this motherboard have only on bios chip
            Use bigger one "LA-E132P BIOS 1.13.0 ME_CLEAN.BIN".
              its working but have a password
                I'm sorry sir this motherboard have 2 bios chip I haven't seen the second one big tanks to you
                  Hold on, stop doing random things, before you mess something more.
                  Give me the markings of both chips, and service tag along with the suffix.
                  Also would like to know why you start messing with the bios? Because there is a bios password or what?
                    yes sometimes we do bullshit even if we often do this work
                    the main bios is winbond 25q128 and the second on is 25q80, yes I'm trying to remove the password
                      : Yea shit happens
                      So what is the situation so far?
                      Original bios is lost.
                      You've programmed the above bios, and now laptop is up and running again, but the password is still present?
                      Am I miss something?
                      P.S.Would be great if you can answer more quickly, I don't have a whole day to wait.
                        yes I lost the bios EC dump because I didn't save it, the second one (main bios) I didn't see it. Now with the 2 files you sent me I can't start the laptop with the adapter, I have to keep pressing the power button for 30sec, and with the batteries only the laptop turns on and off in 6sec with a black screen,it started up once or twice without a password, I don't know if this problem was already or after flashin that bios EC
                          I can confirm that your file is clean there is no password but the laptop is not functional, I can distinguish that the problem is in the EC bios file or a problem in the motherboard ... to be continued
                            Originally posted by nassih View Post
                            y don't know if this problem was already or after flashin that bios EC
                            I told you to stop doing random things already, but you keep doing it I'm afraid. First of all the above bios is password free, I checked this already, secondly do you save your EC bios file, or it's gone with the wind too?
                              yes I save it
                                yes I save it
                                At least that's fine, if you're sure you've programmed both files without errors, just dont do anything for now, I will send you another files in a private message. If you didn't use verification and you are not sure about the content of the chips, do it again properly and try over again. And remove cmos battery, so the board can autostart.
                                  Hi back to our subject, I'm still on the black screen only the power indicator light is on, maybe the bios chip(25q80c) is malfunctioning, before I could see the bios setup I was even able to set the date, after I wanted to install the system and I fell on a black screen after that I restarted and the same problem, I don't think I made a big mistake, maybe I put a bad flash,tanks mr Vesko for your explanation it's nice of you, if you have any other solution i would be very grateful to you
                                    Did you try to flash (with verification of course) both chips again?
                                      Finally, I am saving, I found a dump in the forume of a member named alihomee the file was the same as mine because I remember the file was empty just the first line which had numbers, now the laptop is working perfectly thank you everyone thank you mr vesko for sacrificing a bit of your time since this morning
                                        her is the file
