Asus PCE-AC56
    Asus PCE-AC56
    Hello Folks.
    Today i bought a used Asus AC56 Wlan card.
    The pre owner told me it works.. after i tried it, i cant connect to my
    5G Wlan and the connection is VERY VERY slow... connectivity also very bad.
    So i look at the card.. and vola it seems like there is a missing piece...
    L506 is missing on my card. can this be the issue? is possible to buy this piece and bring the card back to life?
    Problem is.. i dont know what this missing piece is... can someone help me please? it just says 100 on it.
    Re: Asus PCE-AC56
    Is it 100uh or 10uh ?
    Is the resistor and current value of the original Part very important?
      Re: Asus PCE-AC56
      hello... i looked up... there are power inductors... high frequent inductors... the size for that missing piece is about 7mm (square)
      there are so many parameters.... ohm.. ampere... nobody has an idea ?
        Re: Asus PCE-AC56
        if you have spare broken laptop motherboard find similar size inductor, ideally with same marking (100) or as close as you can find...
        solder and test to see if there are any changes
        if you see the improvement, then it makes sense to try to source original part or leave it as is.
        https://www.ebay.com/itm/26495856977...YAAOSw~VhfxRxy
        Im Back... sort of...
