Hey everyone!
I've been dabbling into GPU repair and have more than few cards brought back from the dead successfully. I understand that not all cards are repairable. I do have a SMD rework station, just a cheap one but gets the job done ( and it is calibrated!) and the required tools to do voltage injection.
But with this card, the symptoms are:
-When in PC
- Fans Spin
- Not Detected in BIOS
- Not Detected in Windows
- No Display output.
- GPU silicon does get warm
Checks I have done:
Checked all cables, reseated etc (Have tested the GPU in 3 different systems)
I have checked all voltage rails.
Pex at 1 Volt
1.8 volt stable
12 Volt is stable
5 volt is stable
3.3 Volt is stable
GPU VRM shows standby voltage of .860 Mv after inductor on all VRM Phases.
VRAM voltage at 1.3 volts
Used an SPI Programmer to re-flash the V-bios.
Checked resistance of all V-rails. And they're all within a healthy range. No short or low resistance on VRAM or 1.8, 1 Volt
I have checked for any damaged components, at least the obvious ones. No missing or burnt components no shorts can be detected anywhere, new vbios didn't help.
And this is where I am now lost as I cannot see and also do not know where to test from here as there is no clear direction, at least to my knowledge on where to either probe or replace components.
-When in PC
- Fans Spin
Checks I have done:
Pex at 1 Volt
1.8 volt stable
12 Volt is stable
5 volt is stable
3.3 Volt is stable
