the computer will chime and the baclight comes on for a split second and then goes dark. i can see the image but the backlight stays off. could this be a faulty gpu?
2010 27" imac no backlight
Re: 2010 27" imac no backlight
If you can see an image, the GPU is working.
I believe this is a known issue with this model where the connectivity of the LED wiring becomes disconnected just inside the display.
I don't know if you've see this. It may or may not apply.
https://logi.wiki/index.php/iMac_bac...1419_and_above)
Check to see if the backlight voltage is at the main board even though the display is dark. If that's the case, you may need to do some internal wiring work on the display. There are some YouTube videos on this.
Originally posted by kjchatman View Posti fixed it. the inverter board had a short. can i upgrade to an SSD hard drive without using a 3rd part temperature sensor or will the cpu throttle?
I have a similar problem.
