Anyone encountered this problem ? I attached a photo of how the card is seen in HiveOS . I checked voltages and resistace and they all seem good . Also voltage on the Bios chip . Anyone has any clues or can point me somewhere regarding this ? Thanks
GTX 1060 6GB - Not Recognized Properly
Re: GTX 1060 6GB - Not Recognized Properly
Originally posted by foshland View PostDid you try in windows? look what gpu-z tells about it bios rom, maybe it was modified. What make and model is it?
Originally posted by foshland View PostHi, look at the front and at the back of the card, it uses to have 2 bios chip, dont really know why, but all the nvidia cards I have has 2
Originally posted by Goblin999 View PostYes , I just did that right now . Changed BIOS chip with a reflashed one from TECH and it is the same . I will upload a gpu-z picture . it does not see the BIOS chip as far as I can tell- I didn`t installed the drivers though because it give me a blue screen
Check R740, R753, R741, R728 and C968Last edited by benwaterson; 02-25-2022, 10:28 AM.
Originally posted by Goblin999 View PostI will try the card in mats and see wheter it gets recognized or not
I managed to run MATS by booting with a primary card. Full of read errors.
I was thinking vBIOS, either the chip or the actual vBIOS. The one on TechPowerUp in unverified, but the same as the one on the card. I bought the card not working so do not know if the previous owner flashed the TechPowerUp vBIOS. I'm trying to track down someone with a working card with a known good vBIOS.
Originally posted by manuforti1314 View PostI have a GTX 1060 6gb Inno 3D Compact. Doing exactly the same thing. Mine loads the up to date drivers fine in Windows. Just GPU-Z is missing info and the sensors tab has only 4 sensor readings, which look wrong.
Originally posted by Goblin999 View Postsame problem here . I think we may have bad ram modules buddy
I'd love to just know if it is just one module, should be able to change that.
Originally posted by manuforti1314 View PostAn update on my INNO GTX 1060 Compact, flashed the stock Founders Edition vBIOS and things have changed a bit.
Seeing more in GPU-Z.
Need to do more work. I would love get an official dump from one of these cards. Might help even more.
