Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals
Old 01-07-2014, 07:21 AM   #21
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
Default Re: [HOWTO] Fix/Repair "Chassis Intruded Fatal Error System Halted" on Asus P5QL
too good of caps?
Originally Posted by tmiha71 View Post
Nice thread, but I see lot of Panasonic's FJ caps...
If there are at the rear USB connectors, I would replace them with Rubycon XYG 8x11 1000uF, even used ones are good for that place...
Reason for replacement - too good caps (??), on wrong place ...
To add, through time, inductive, capacitive, or even resistive bond is created, and is main cause of that behavior...
Most likely some caps died, and can not swallow current... And because they're FJ's - most likely PSU caps took big hit...
kc8adu is offline   Reply With Quote
Old 01-07-2014, 11:49 PM   #22
momaka
master hoarder
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Originally Posted by kc8adu View Post
x2
I don't see how "too good of caps" would cause a problem either. The PSU's wires have enough resistance so that the PSU never really "sees" the low ESR of those "too good caps" on the motherboard.
Old 01-08-2014, 05:20 AM   #23
tmiha71
That's for sure, that PSU wires have higher resistance than traces on mobo....
ROFL
tmiha71 is offline   Reply With Quote
Old 01-26-2014, 02:45 PM   #24
fu-raz
City & State: Almere
My Country: Netherlands
This helped me fix my Asus P5E deluxe. It also had the Chassis Intruded fatal error. Took me only a few seconds to find the right transistor, thanks to the directions.
It's not perfect yet. Is it possible that my 3.3v point comes on too late? If I do a cold boot it gives me the error, but when I reset everything is fine.
Anyway, I wanted to say thanks and give people looking for a solution for their P5E deluxe some directions. So I added a picture of the fix for the P5E deluxe. The transistor is located in the bottom left corner of the motherboard. Underneath the winbond chip.
fu-raz is offline   Reply With Quote
Old 01-27-2014, 12:33 PM   #25
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
I see you pulled 3.3v from a resistor. Maybe that's part of some other circuit and it takes a little while to charge. Try finding a capacitor with 3.3v on it, that should charge up quickly (as it'll be directly across a 3.3v regulator) and it should work on a cold boot as well.
The capacitors are the brown colored parts with no marking on them.
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 01-28-2014, 12:59 PM   #26
fu-raz
Thanks, I'll find another spot and post the picture. If it goes into hibernation or sleep mode now, I can't get the computer to turn back on heheh
Still, this is a lot better than Chassis Intruded: Fatal Error...
Old 01-29-2014, 05:14 AM   #27
fu-raz
I found a new spot, but it seems that I can't get my computer to wake up anymore if it goes to sleep, and also it doesn't want to turn off anymore. Could this have something to do with it? Should I just find an alternate point again?
Old 01-29-2014, 05:50 AM   #28
Th3_uN1Qu3
Believe in
My Country: Romania
Shouldn't happen. What happens when you try to turn the computer off? Do the fans remain spinning?
Try to clear CMOS again and also clean that area on the board well using isopropyl alcohol and a toothbrush.
Old 01-29-2014, 06:12 AM   #29
fu-raz
Yes, the fans remain spinning. I'll clear the CMOS again and I'll clean the board.
Old 01-29-2014, 12:07 PM   #30
fu-raz
So, there we go... Thanks for the help Th3_uN1Qu3! Found a new 3.3v point, cleaned the board and reset the CMOS. Everything is working now.
In the attachment is my final solution for the Asus P5E Deluxe
Old 01-29-2014, 12:58 PM   #31
Th3_uN1Qu3
Believe in
My Country: Romania
Good job! Another board saved from the landfill.
Old 02-13-2014, 09:25 PM   #32
wasay345
City & State: karachi
My Country: pakistan
can u plz help me my motherboard is P5k-VM
and i also get the same problem (chassis intruded fatal error system halted)
dont know how to fix that :/
wasay345 is offline   Reply With Quote
Old 04-01-2014, 04:06 PM   #33
jimmyd
City & State: Fort Walton Beach,Florida
I know this is an old thread but I have a P5E3 with same problem. My chassis intrusion connector is by the front panel header and the board power LED and the super I/O controller is in the top corner like the P5KE shown but no transistors are near it. Can anyone help me identify the correct sot-23 on my board? I certainly would appreciate it. There are 4 transistors surrounding the intrusion connector but none are marked sot-23.
jimmyd is offline   Reply With Quote
Old 04-03-2014, 11:30 PM   #34
momaka
master hoarder
momaka's Avatar
My Country: U.S.A.
SOT-23 is just the package specification (look up SOT-23 on Google images and you will see what I mean). The actual marking on the transistor will vary, depending on what it is.
Old 07-28-2014, 08:22 AM   #35
gn2
City & State: Kingston
My Country: Canada
I have seen this error on a P6T Deluxe V2 socket 1366 motherboard, is it likely the same solution ?
Also, it appears that cleaning the board well could resolve this as well, is that correct ?
As old as this thread is, its the first solution I've seen, in a LOT of looking, that seems to delineate the exact CAUSE of the fault. Very, very useful information.
Thanks very much to the OP, btw !
gn2 is offline   Reply With Quote
Old 07-28-2014, 10:09 AM   #36
stj
stj's Avatar
City & State: Europe
try replacing the jumper that bypasses the chassis switch
Old 08-07-2014, 11:47 AM   #37
Vishwasjoistmk
City & State: Tumkur
My Country: India
Thumbs up Re: [HOWTO] Fix/Repair "Chassis Intruded Fatal Error System Halted" on Asus P5QL
Have an easier workaround, following are the steps :
<1> Remove the front USB and audio connectors from MB
<2> Remove the reset switch connector
<3> Reset BIOS using the Jumper / removing CMOS
<4> Reset BIOS Settings and reboot your PC and things should be Up and running.
Let me know if this works for you too.
Vishwasjoistmk is offline   Reply With Quote
Old 08-14-2014, 10:42 AM   #38
formybhe
City & State: Quezon
My Country: Philippines
got same problem on my P8h61-m2, help me please! tia
formybhe is offline   Reply With Quote
Old 09-01-2014, 07:15 AM   #39
bobbymih
City & State: Prahova
My Country: Romania
Th3_uN1Qu3
Please help me with my PK5 DELUXE mother board that surely need that "remove transitor fix" cant know for sure wich one is it and i don't wanna mess something up.
bobbymih is offline   Reply With Quote
Old 09-01-2014, 07:21 AM   #40
Th3_uN1Qu3
Believe in
My Country: Romania
Please post clear pictures of the mainboard and a close-up of the Winbond chip area.
Badcaps.net Technical Forums © 2003 - 2022
