Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals
Old 06-10-2015, 02:11 PM   #61
mandinger
City & State: Matanzas
My Country: Cuba
Default Re: [HOWTO] Fix/Repair "Chassis Intruded Fatal Error System Halted" on Asus P5QL
i have an asus p5kpl-cm with the same problem, i got no problem locating the transistors but it seems did n´t work the same way you described in this post.for example i dont have any voltage measure at the chasis pins, there is three pins , one with 5 v and the others have nothing.maybe is that my board is not like you find the fix.i even try to find a beep of the meter trying all pins with all transistors near winbond chip,and i got no condictivity in any of them i find just a litlle pas of current but with resistance in all transistors , please help if there is a way you can help me i´ll be grateful
mandinger is offline   Reply With Quote
Old 06-12-2015, 01:07 PM   #62
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
Will try and find a solution for you in a few days. Until then, please post some pictures of your board.
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 06-15-2015, 01:48 AM   #63
fullmetaljkt
City & State: naples
My Country: italy
Th3_uN1Qu3 Hello, congratulations for howto.
Even in Italy we need your help. :-)
I enclose a picture of my motherboard.
Can you tell me what to do to fix "Chassis intruted ...!" ?
I am deeply grateful to you!
Thanks a lot!
fullmetaljkt is offline   Reply With Quote
Old 06-15-2015, 06:58 AM   #64
fullmetaljkt
My Country: italy
Ok, better reading the instructions I found the transistor to be deleted.
It is valid as I pictured?
Now, you could tell me how to complete the task?
Unfortunately I can not interpret the instructions.
Thanks a lot!
Old 06-17-2015, 12:45 PM   #65
Th3_uN1Qu3
Believe in
My Country: Romania
That is a SOT-23 transistor and it looks like so: http://gtsemic.com/uploadfile/20140807140911319.jpg
You see how it has 3 pins. Two at the bottom and 1 at the top. You need to remove it (use a hot air station, you may damage the board if you try to remove it with the iron) and solder a wire from a 3.3v supply to where the pin at the top went.
Here is how you find a 3.3v supply in that area. With the board connected to a PSU and powered on, take your multimeter and measure on the capacitors around the Winbond chip (small brown things). Black probe of multimeter to ground (computer case or any black wire from connectors of PSU), and touch red probe to each of the small brown capacitors.
You need to find a 3.3 volt reading on your multimeter. When you have found it, power the board off, solder a thin wire from that point and take it to where the top pin of that transistor was. Then clear CMOS again, power the board back on and be happy.
Old 06-19-2015, 10:27 AM   #66
fullmetaljkt
My Country: italy
ok , I'll try to do it as well as you say .. These components are very small . I have not many possibilities ! I 'll tell you what will happen to the motherboard !
For the current regulation to 3.3v , I can use this :
" STEP DOWN LM2596S 5V power supply 12V 2A " ?
http://www.ebay.it/itm/Convertitore-...item3ce7305eb1
I wait for your opinion before starting work
Thanks a lot!
Old 06-20-2015, 04:10 AM   #67
Th3_uN1Qu3
Believe in
My Country: Romania
You do not need to add an extra power supply, you will find it on the board. Worst case take it from an orange wire of the PSU, although that will be kinda long. But it will work like that too.
Old 06-20-2015, 07:41 AM   #68
fullmetaljkt
My Country: italy
Hello ,
forgive me again .
I found two transistors on the motherboard .
Which of the two I have to remove ?
Thank you very much for your very important assistance
Old 05-09-2016, 01:31 PM   #69
drag
City & State: lapland
My Country: finland
Is this good fix/repair?
https://www.youtube.com/watch?v=x2cJbefy1Fc
drag is offline   Reply With Quote
Old 05-10-2016, 08:02 PM   #70
momaka
master hoarder
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Originally Posted by drag View Post
I think it is somewhat similar to Th3_uN1Qu3's fix, so probably yes. Unfortunately, I don't speak Spanish very well (actually very little, though I was able to understand some parts of the video), so I can't tell you with 100% confidence that this video shows a good repair or not. But I am guessing it probably does. Hope this helps.
Old 05-11-2016, 09:01 AM   #71
drag
My Country: finland
I have Asus P6T SE. Do you know how to do this repair for Asus P6T SE?
Old 05-11-2016, 03:01 PM   #72
momaka
master hoarder
momaka's Avatar
My Country: U.S.A.
Not specifically, since I don't have this motherboard.
According to one comment in the above video, the fix worked for a P6T, so my guess is this should be similar for the P6T SE as well. Thus just do what the guy in the video did - find the Chassis Intrusion jumper and see which transistor on the board it connects to. From there you can either follow the video or Th3_uN1Qu3's advice.
If that doesn't help, you can always post pictures of your board here and we can try to troubleshoot that with you .
Old 05-14-2016, 01:04 AM   #73
drag
My Country: finland
Chassis intrusion jumper has (propably all motherboards) +5vsb first, then empty, then chassis signal and then ground.
Th3_uN1Qu3 instructions say that "With the board powered ON, measure with your voltmeter and find the pin of the chassis intrusion switch connector that has somewhere between 1.7v and 3.3v on it.
Power the board back ON and find a 3.3v supply nearby"
I wonder that video shows +5vsb to supply?
Sorry for my bad english.
Old 05-18-2016, 03:42 PM   #74
momaka
master hoarder
momaka's Avatar
My Country: U.S.A.
The chassis signal should be tied directly to the gate on a small SOT-23 transistor somewhere on the board either near the Super IO chip or near the chassis intrusion connector itself. Find that transistor, remove it, and tie the Drain pad to 3.3V rail. The video shows to do that without removing the transistor and typing the Drain to 5VSB. But ultimately, you get the same results. The only problem with the video is if that transistor somehow got turned ON while you have the Drain pin tied to 3.3/5V - then that would cause the transistor to smoke.
Old 05-20-2016, 10:38 AM   #75
drag
My Country: finland
Finally after 2 hours intensive searching I find the beeping transistor on Asus P6T SE near the BIOS chip!!!!
Old 05-21-2016, 06:12 PM   #76
momaka
master hoarder
momaka's Avatar
My Country: U.S.A.
And? Did you get the fix to work?
Old 05-29-2016, 02:08 PM   #77
drag
My Country: finland
No, I search 3.3v supply but not find it and then accidentally touch something
and there was short and motherboard are broken...
Maybe someone know how to repair it.
Old 05-29-2016, 07:10 PM   #78
momaka
master hoarder
momaka's Avatar
My Country: U.S.A.
Hard to give you more advice how to repair it without pictures and more info. Need to know what you shorted, what the motherboard does now, etc.
Worst case, put it on eBay for sale as "parts or not working" and mention the problem.
Old 06-02-2016, 06:24 PM   #79
mockingbird
mockingbird's Avatar
Does anyone know how to fix "New CPU is inserted in your system !"?
This is on an Asus M4A78LT-M-LE
This happens after a hard power off with the PSU switched off and a power loss to the motherboard. The CMOS battery has been replaced with a fresh Duracell to no avail.
"...I suppose he wants to be free of youthful associations, as most of us do."
-Robertson Davies
"...don't say oh my god, your god is far away from you. I give you massage. I am your god now."
-Luo Dong
mockingbird is offline   Reply With Quote
Old 06-02-2016, 09:02 PM   #80
mockingbird
This guy claims it's caused by a substandard Asus socket:
Might just try tightening the retention bracket... If not, I should have some motherboards around here with some spare sockets...
Badcaps.net Technical Forums © 2003 - 2022
