Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals
Old 06-16-2020, 04:44 AM   #121
loli_roller
City & State: Gujarat
My Country: India
Default Re: [HOWTO] Fix/Repair "Chassis Intruded Fatal Error System Halted" on Asus P5QL
Originally Posted by Th3_uN1Qu3 View Post
Ok that's a good pic. With the board powered ON, measure voltage at the CHASSIS jumper. Find the pin that has somewhere between 1 volt and 3.3v. Could be anything in that range.
Once you found it, turn all power OFF and unplug the power supply, and set your multimeter to beeper. One probe goes to that pin you found with the voltage on it, and with the other probe measure on the little 3-pin transistors around the Winbond chip. You should find one that beeps on the single pin at the top, which would be the collector or drain.
Return with these results and i will try to help you further.
Hi Th3_uN1Qu3, First of all thanks for posting this solution and keeping this thread alive. I have Asus m5a78l-m lx v2, i dont see any 3 pin transistors near the Super I/O Chip but there is another small chip below the super I/O chip that has those transistors.
loli_roller is offline   Reply With Quote
Old 08-18-2020, 06:10 PM   #122
mockingbird
mockingbird's Avatar
There is a dual diode which feeds power to CMOS memory from two places: 5VSB rail of PSU via 3.3V regulator, and the coin cell. You should trace the circuit going from the coin cell holder until you get to that diode. Either the diode is bad or a leaking battery corroded the trace so the battery simply does not get connected to the circuit.
It's been some time, finally making some progress with old projects here...
I found the diode, it tests fine. It comes after a resistor marked 01B (1Kohm) which tests fine. There is a 0.2V forward voltage on both pins.
I think this has more to do with a quirk on some Asus motherboards than it has to do with a defective battery circuit. I only have this problem on my P5PE-VM with a certain CPU installed, and I do have an unsupported CPU (Xeon hack) running in this one, so I might just try it with my Q9650 instead.
My question is: What exactly keeps the SPI alive during a no power state when there is no voltage showing on any of the SPI pins... I tested this on a different motherboard, I installed a battery, and I do not see 3V on the VCC pin of the SPI chip. Unless of course there's supposed to always be 3V on VCC, but I don't remember this other motherboard exhibiting this same issue (Asus P5B).
"...I suppose he wants to be free of youthful associations, as most of us do."
-Robertson Davies
"...don't say oh my god, your god is far away from you. I give you massage. I am your god now."
-Luo Dong
mockingbird is offline   Reply With Quote
Old 10-31-2020, 02:24 PM   #123
Mister_Natural
City & State: Naveil
My Country: France
Thanks to this thread and contributors, I finally managed to boot that old Asus at5nm10-i (Atom inside). The chassis-intruded sot-23 diode on this model can be found up to the second 'c' of the label 'clrtc' near an angle of the mobo, if somebody else got one if those relics and need a fast-11-years-repair.
Mister_Natural is offline   Reply With Quote
Old 10-31-2020, 04:37 PM   #124
RJARRRPCGP
City & State: North Springfield, Vermont
Line Voltage: 118-127V 59-63.5 Hz-> actualizo: pérdido de voltaje
Reminds me of my Asus socket 1366 motherboard, using a Radeon RX580, causes to CMOS to get reset, a bad bug!
If this is to do with video card chronology, looks like for Nvidia, would possibly mean you can't install a later video card than a GeForce GTX 980 series on an Asus pre-UEFI motherboard and possibly a Radeon R9 290X for AMD video cards. (suspect it's the VBIOS)
ASRock B550 PG Velocita
Ryzen 5 "Vermeer" 5600X
32 GB G.Skill Trident Z Neo F4-3600C18D-32GTZN
Sapphire Nitro+ Radeon RX 6600 XT
eVGA Supernova G3 750W
"¡Me encanta "Me Encanta o Enlistarlo con Hilary Farr"!" -mí mismo
RJARRRPCGP is offline   Reply With Quote
Old 12-20-2020, 06:13 AM   #125
selekop
City & State: ankara
My Country: türkiye
This is what mk I don't understand.
selekop is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2022
