Fixing a laboratory waterbath
  • petehall347
    • Jan 2015
    • 4424
    • United Kingdom
    #101
    Re: Fixing a laboratory waterbath
    no idea how much free space is in the connector pass throughs on the board but maybe pinning through with single strands of wire might help .
    • vrasp
      • Nov 2019
      • 194
      I dont have anything that small. It looks like the inside has metal "tweezers" that hold the pin when inside and I dont want to deform them.
      I m letting the board sit in 99% isopropanol overnight. Hopefully it s gonna dislodge whatever is in there. I suspect somebody in the lab spilled some sticky solution in there. I was also able to melt some solder where the holes are to make them smaller. The pins dont get in rhat easily but at least there is contact.
      Now why did the car lamp start flickering when the LED board was on I dont know. Something grounded? The LED board barely has anything on it. I guess it might make it easier to solve.
        • Jul 2011
        • 6026
        The pin connection on the right hand side of the green looks like crap it appears to be flux from the picture if so re-solder them or is it just the way the picture was taken
        • vrasp
          • Nov 2019
          • 194
          It s not the way the picture looks. It was actually quite bad. Cleaned it off but havent reappplied solder yet.
          Is the car lamp blinking for sure caused by a short to ground in the LED board if it only happens when it is connected?
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8678
            If that car lamp glows very brightly, interpret it as if you just had to stick in another fuse.
            • vrasp
              • Nov 2019
              • 194
              It s not very bright. You can just see the filament warm up. And now that I think about it, it could just be blinking because of the constantly changing number on the LED which varies the power drawn.
              Could it just be normal that the car light lights up slightly? I dont wanna look for an issue where there is none.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8678
                Yes it's fine for it to be dim. Don't worry about it, it's expected.
                The sole alert is if that it glows brightly - it saved you from replacing another fuse.
                • vrasp
                  • Nov 2019
                  • 194
                  While I try to figure out how to properly fix the connections between boards, can someone explain to me how the knob system works? In this case, the knob serves to pick a preset temperature.
                  Is the plastic knob supposed to have a circuit that touches the the metal parts of opposite sides to activate the circuit? I m just guessing here. I need to understand how it works to see hownit can be fixed.
                  The actual knob (not shown in this picture) goes into the white round thing on the top board of this picture.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8678
                    That's about it, just selects different resistors...
                    • vrasp
                      • Nov 2019
                      • 194
                      Thank you. I was asking because the knob I have does not have any metal in it. I think I might have broken it while trying to remove it from the board and maybe the metal part got lost.
                      I think I m going to buy a new rotary switch. The one on the board works by creating a contact between the center golden circle and the outer golden metal. I d like to get a similar one. Is there a specific name for this?
                      If you have other suggestions to replace this switch let me know! Thank you
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8678
                        if you're inclined to look for the small metal piece lost, it probably looks like a bent leaf.
                        The unfortunate thing is that getting an exact match will be hard...mainly to fit in the board. Rotary select switch is pretty much is all you can look for, and it appears to be a 5 throw 2 pole (DP5T) rotary (of which it really just needs 1 pole but the original designer appears to have cheesed the switch to make it easier to route PCB tracks?) perhaps if you can't find the leaf it's easier to just hardwire it to the adjustable setting?
                        • vrasp
                          • Nov 2019
                          • 194
                          I didnt think of that! That would save me the trouble of looking for a proper rotary switch. I m gonna see if I can do that right now.
                          • vrasp
                            • Nov 2019
                            • 194
                            How do I hardwire it? I thought I just had to wire the fifth outer pin (that corresponds to the manual temperature selection) to the inner pin (golden metal ring). Things started getting smoky and I turned it off immediately. The smoke came from one of the capacitors or the resistance next to it. I think I reacted quickly enough. If I have to replace it it's no big deal. However, I don't understand what pins to wire.
                            Basically, I did this:
                            • vrasp
                              • Nov 2019
                              • 194
                              The capacitor is fine. It is the resistance that blew.
                              Are you able to see the lines? I can't tell what ohm this is.
                              • petehall347
                                • Jan 2015
                                • 4424
                                • United Kingdom
                                #115
                                go through your pictures to find a good close up of the resistor .
                                • vrasp
                                  • Nov 2019
                                  • 194
                                  I did, it s really difficult to see.
                                  The bands look like Red brown something (grey?) brown red. Of course the blown resistor had to be the one that is the least visible in the pictures.
                                  Is there a trick to figure out the resistance of a blwon resistor before it blew?
                                  • petehall347
                                    • Jan 2015
                                    • 4424
                                    • United Kingdom
                                    #117
                                    tell us what it connects to ?
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8678
                                      appears to be a kind of jumper... which could explain the need for 20V as there'll be a drop across this resistor to reduce heating of the regulator...
                                      • vrasp
                                        • Nov 2019
                                        • 194
                                        It's getting 20v AC from the transformer and on the output it goes to the bridge rectifier which goes to the voltage regulator.
                                        The voltage regulator is a 7812. If I am able to find out more or less how much current is in this circuit I can calculate the resistance needed to lower the voltage from the 18v of my toroidal transformer to about 13-15v. Is that a good approach? I could connect my multimeter in series to measure the current where the resistor was, and calculate a resistance that would drop the voltage by, let's say, 5v.
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8678
                                          The resistor may still be good. Measure it.
                                          I don't understand why it smoked, sure you didn't short something else by mistake?
                                          • ohren
                                            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                            by ohren
                                            Hello!
                                            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                            Measured voltages with no load:
                                            After rectifier diodes
                                            12V: 6.17 V
                                            5V: 5.67 V
                                            Secondary transformer pins AC measurement (really don't know if this says anything)
                                            12V: 2-2.5 V
                                            5V: 1.04 V
                                            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                            03-18-2023, 10:33 AM
                                          • mikey5791
                                            Is it possible for transformer substitution?
                                            by mikey5791
                                            Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                            Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                            My questions are
                                            1. How do i test to see if the transformer is in good working condition?
                                            2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                            Hope you guys understand what i was asking. My intention is...
                                            11-03-2022, 02:11 AM
                                          • dennis_elx33
                                            3PHASE STEP-DOWN Transformer in Check
                                            by dennis_elx33
                                            Hello All,
                                            i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                            Problem statement: Power tripped Off
                                            Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                            Action Done:
                                            1) Replaced the faulty parts with good spare.
                                            2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                            12-02-2024, 06:52 AM
                                            ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                            This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 04:40 PM
                                            ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                                            This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 12:00 PM
