Re: Vizio E65-E3 Dead after backlight replacement
EDit: because you cant refund them i guess, you can try this theory which i didn't try it before... but the principle of it make sense.
you add DO-35 type glass zener diode ( signal switching diode ) with specification such Maximum Reverse Voltage 100V, and Maximum Forward Current 400mA. they are very cheap round 5 cents each.. and solder them on each diode where the points you have on the strips as you made test before.
give it a try.
give it a try.
