Hi Folks,
I had a Phillips 42 in. LCD come into the shop today with NO backlight but had sound.After looking for the usual suspect bad caps in the power supply (which there were none bulged)After inspecting the left side small inverter I found the 2, 470uf 35volt caps were bulged and the 10 amp pico fuse was open.This seems to be a fairly common problem with similar model Phillios TV's
Cheers,
Ed
Cheers,
Ed
