Remove_SMM... UEFI.
    Re: Remove_SMM... UEFI.
    Originally posted by Ghamidi View Post
    try this file and valid with any key
    Thank you so much, this patch file work fine! Great job.
      Originally posted by aldopc View Post
      Try this how it went with the x1 carbon patch
      not working
      it stuck ,look to pics in attachments
        Originally posted by daasco View Post
        not working
          I am new to this. So if i want to reflash bios to remove the password, I will need the original bios dump? I cannot just rewrite the patched bin file that I can find here?
          I have a T440 here. But unfortunately, the laptop was unable to power on after I program a patched T440.bin file that I got from here.
            This means I need the original bios dump. Then replace body for boot option and lenovotranslateservice using UEFItool, and then save a new image. After which I will reflash bios and I should be able to remove my bios lock right?
              same as before WITH NEW SCREEN
                same as before
                1. Remove The Battery CMOS . Also make sure laptop's main battery is out and disconnect the internal front battery if used (many new Lenovo may have an internal battery, the black box) by removing its connector from the motherboard. It is important that the laptop will have NO The main Battery attached and the NO Battery CMOS .
                2. Insert other LOCK HDD OR SSD M.2 ( by the way use another laptop set up password lock HDD and remember your password )
                3. ReFlash BIOS with patched file
                4. The First Step Let Press Down and Still Keep Little Switch ( picture attached ) long time and The Second Step Let Plug in the AC adapter and wait for a few seconds, the laptop will start by itself (if not, press the Power button and start it). You may hear some beeps then you will see the Lenovo splash image, press F1 to get the SVP password prompt and enter "1234" for SVP and press Enter. Next page will showing "Press any key..". Wait about 10 to 12 seconds before pressing any Key. Next it will display the warning message and the laptop hardware ID. Do not disconnect the AC during this process!
                  Hi everybody! Is there any solution for T440p?
                    1. Remove the battery cmos . Also make sure laptop's main battery is out and disconnect the internal front battery if used (many new lenovo may have an internal battery, the black box) by removing its connector from the motherboard. It is important that the laptop will have no the main battery attached and the no battery cmos .
                    2. Insert other lock hdd or ssd m.2 ( by the way use another laptop set up password lock hdd and remember your password )
                    3. Reflash bios with patched file
                    4. The first step let press down and still keep little switch ( picture attached ) long time and the second step let plug in the ac adapter and wait for a few seconds, the laptop will start by itself (if not, press the power button and start it). You may hear some beeps then you will see the lenovo splash image, press f1 to get the svp password prompt and enter "1234" for svp and press enter. Next page will showing "press any key..". Wait about 10 to 12 seconds before pressing any key. Next it will display the warning message and the laptop hardware id. Do not disconnect the ac during this process!
                    i did all steps you mentioned and i press 1234 and hardware id appeared after pressing enter i wait for moment message appear that security reset
                    and pressed power button then again on but laptop stuck
                    you can see the picture
                    thank you
                      thank you
                      KEY :1234567
                      . Now you need to press Space twice
                      . You can now power off the lenovo and reflash the original dump
                        thank you
                        SEE THIS VIDEO https://www.youtube.com/watch?v=171_Wfm-e80
                          I DID AND ITS WORKED
                          THANK YOU SO MUCH
                            i did and its worked
                            Thank you so much
                            you welcome bro
                              Can Anyone patch T470s ?
                              Is it same like T470?
                              Bootoption and Lenovotranslateservice?
                                Originally posted by 530v8 View Post
                                can anyone patch t470s ?
                                Is it same like t470?
                                Bootoption and lenovotranslateservice?
                                try this file and valid with any key exemple 1234567
                                  not working
                                  There it was ready you just had to load your original dump and ready ...
                                    thanks already solved with other patched bin file from here
                                      Do not give me a fish to eat, but teach me how to fish
                                      any one can learn me?
                                      Best Regards
                                        Read this topic from the beginning to end and then try following instructions you found.
                                          can be unlock thinkpad with out patch?
