medion akoya s2217
    medion akoya s2217
    Hi.
    I have a laptop with bios locked by password.
    i need if someone has an unlock tool.
    or a clean dump of the bios.
    the laptop is a medion akoya s2217. md 99861. msn 30020362.
    thanks for your help.
    Re: medion akoya s2217
    Originally posted by cafanu View Post
    Hi.
    Post your bios backup .
      thanks for answering,SMDFlea.
      still don't have an eeprom reader.
      Which one do you advise me to buy?
        carries a bios: winbond 25Q160WSIG
          A CH341A with 1.8V adapter will do .Use NeoProgrammer software,and choose W25Q16FW 1.8V - https://www.badcaps.net/forum/showpo...04&postcount=7
            thanks for your help, SMDFlea.
            As soon as I receive it and read it, I will send it to you.
              hello SMDFlea.
              I already have the bios dump.
              I hope it turned out well.
                Hi.
                Happy New Year to everyone.
                Can somebody help me?.
                I do not know if this dump is well removed since it is the first time that I do it.
                thanks.
                  Hello everyone.
                  I have done a new reading of my bios, disconnecting everything from the motherboard and I got a different reading.
                  I upload it in case someone can help me with my problem.
                  thank you.
                  sorry for my english but it is done with google translator
                    Hello everyone.
                    thank you.
                    Have you desoldered the chip .
                      Hello
                      I have only disconnected everything that was connected to the plate and removed it.
                      I have not unsoldered the chip.
                      do you think i should desolder it?
                        Hello
                        Yes and solder it to an adapter.
                          ok I will try and upload the result.
                          thanks.
                            Here is a copy of the BIOS removed from the motherboard.
                            I also generated a different reading from the previous ones.
                            thanks.
                              Always make two readings, open with hex editor and compare, when you get both the same, save as backup. I use HxD. I always desolder, the clip adapters never worked for me, and place chip into another adapter for reading/programming. Anyway, I cleaned the ME Region, hope that fixes your problem. I'm bilingual, we speak Spanish here in Texas.
                                Thanks for answering so quickly Mazorca.
                                I'm going to solder and test.
                                anyway I desoldered it and I have read it with the tweezers since I do not have another adapter, although I have already requested it.
                                thanks
                                  I have programmed the chip and soldered it.
                                  the screen does not turn on
                                      try..
                                        thanks peste, for your help.
                                        I'm going to test the file and I will tell you the result.
