quick plasma question lg 42 pa 4500
    with the tv unplugged and not in use:
    if a plasma screen has a yellowish patch or tinge
    is this a sign that the panel is gassed
    or worn?
    its hard to photograph
    but in daylight instead of being a uniform black,
    it looks yellowish in the corner ,theres no sign of cabinet damage.
    Re: quick plasma question lg 42 pa 4500
    anybody comment please
      Bit of a mission , but all i can think of is removing display to clean .
        It does look like this model has a uv filter in front of the plasma panel so either the uv filter or the front of the panel would need to be cleaned.
          i was given this set and its s/c igbts on y sus ,
          before i order parts i just wanted to know if im wasting my time if the display panel is duff thanks,
          as ive never seen this yellowing before .
          in the old days of crts the phosphor used on some crts was greenish
            Where did you get the tv? did the place have people that smoked?
              no tv is clean no smell of cigs,i was told it hadnt been used for a while
                sorted
                for anyone with similar conditions the front reflection diffuser glass was removed and it was clear some of the coating had faded
                i assume when it was not in use it had direct sunlight on it for years
                in no way does it affect pic when in use
