Hi friends, i have this laptop ( rev G ) i see on youtube that for 2 long beep and 2 short beeps it's necessary to reflash the BIOS eprom.
the eprom name is Winbond 25q128fvsq
i have 2 programmer CH341 (GOLD type) .. and a new TL866II PLUS...
i think thatthe TL866II PLUS is the better to flash the image, but i tried with all these roms (maybe i ve no tried the CLEAN version) , everything seems ok but the laptop just start, the fan is spinning (increasing speed) but there are no beeps.
i'm not whure if i'm selecting the correct flashing procedure, beacuse i have 2 choices:
Winbond 25q128fv
Winbond 25q128fv (OTP)
(these 2 with soic8 or soic16... and i think soic8 is the right choice)
bat what i need to select? i used always the 1st choice (NOT OTP)
if i select the OTP i have more choices when loading the dump...
for example: "to region" that can be: Default, FLASH, OTP secu.R
or .. "file format" that i think it's correct with: BINARY (and not intel HEX)
anyone can help me to be sure that i was programming the eprom correctly before starting searching something else on logic board.
Hi Peste, i have the manual and i readed/programmed also some Asrock/Asus bios chips with success... the only thing i can't understand is if these dumps (posted here) needs the (OTP) selection (on eprom type) ... just asking if someone that own this programmer can explain how to re-flash these dumps, just to be sure that i'm doing everyhting in the right mode.
