Panasonic Viera tv P46st30 no standby light
    Hi guys,
    I have this Panasonic plasma tv which exhibit a no standby led. I read through a few posts and even bought a new A board from eBay and the set still has no standby light. I am measuring standby voltage of 4.99vdc at P6 pin 6 on the P board. Any help will be appreciated.
    Photos attached.
    Thanks in advance
    Re: Panasonic Viera tv P46st30 no standby light
    Press the power button for 5 seconds, release, and then press it again to see if there is any blink codes present.
      Hi tvtimmy,
      Thanks for replying. I pressed the POWER button for 5 seconds and released and press's it again and there is no blink codes.
      Thanks in advance.
        yours photo
        the mainboards its working and you have the Optical Audio OUT LED indicator lid ON ..!!! so you should have the 15V on power boards..
          Thanks Diah.
          What do you guys think is the next course of action.
          Thanks again guys
            This is the measurements on all pins on P6
            Pin 15 (15Vs) = .922vdc
            Pin 14 (GND)
            Pin 13 (15Vs) = .922vdc
            Pin 12 (GND)
            Pin 11 (F15V) = 15.73vdc
            Pin 10 (F15V) = 15.73vdc
            Pin 9 (GND)
            Pin 8 (GND)
            Pin 7 (F_STANDBY_ON) = 4.98vdc
            Pin 6 (STBY 5V) = 4.98Vdc
            Pin 5 (STBY 5V_ON) = 25.8mv
            Pin 4 (SOS4_PS) = 0.1mv
            Pin 3 (S0) = 09.2mv
            Pin 2 (S1) = 09.3mv
            Pin 1 ( Panel_Main_ON) = 3.8mv
            Thanks guys for your help again. Is it a power supply related issue?
              Any help guys.
                Check s20on the sc board for a short across the 2pins.
                  Hi tvtimmy, which 2 pins on SC20 should a check the short on?
                    Sorry, I meant SN2. Check across the unplugged connector pins. A beep longer than 3 seconds means you have a short.
                      I can't seem to locate the SN2. Is it on the scan board?
                        The power supply in this schematic could be similar to your. Page 49
                          Thanks dick_barton. I will take a look at it. Is it a power supply related issue?
                            I really do not know. It's just looking at the schematic it shows that Pin 15 & PIn 13 of P6 are not at 15V. It could be that it is not being switched on.
                            Q500 is switched on and the 15V at the input is routed to Pin 10 & Pin 11 of P6.
                            The input to Q500 (at 15V) also goes to the input of Q502.
                            I would check the voltages on the pins of Q502
                            Edit
                            I wonder if Panel_Main_On should be at 5V to switch on Q502 (page36) This signal is sent by the mainboard to the power supply.(Page 33)
                              Thanks dick_barton.
                              For some reason I cannot locate Q502 nor Q500 on the power supply board or just my eyes are no longer good.
                              I have attached the back side of my power supply board.
                                The sn board is tbe one with all tbe brown ribbon connections. Here is the sn2.
                                  What voltage do you have for Vda (Connector P35) and Vsus (Connector P11 Pin1)
                                    With the set off can you measure the resistance of P6 Pin15 to ground and also pin 13 to ground.
                                      i am not good at plasma .. but his set working .. if he feed signal will hear sound .. standby light.. he mean indicator ? press the power on RC to turn off and you will have red LED indicator.. LOL... or my bad English a reason i didn't understood his question !!
                                        tvtimmy, the measurements on SC20 on my board reads short(00.0ohm)
                                        @ dick_barton, when the set is off, pin 15 to ground measures 5.05kohms. pin 13 to ground also measures 5.05kohm
                                        When AC is plug in, P11 pin 1 measures 0.922vdc
                                        P35 pin 1 vdata 0.9mvdc
                                        @ Diah, what exactly do you want me to try.
                                        Thanks guys for all your help
