LG 42PQ6000 plasma
    LG 42PQ6000 plasma
    Hi to all
    I have a LG 42PQ6000 seems to be stuck in standby
    after plugging in to the wall the only thing you can get is red led when you turn the button I/O on or off, the first few times i tried this i did get relays clicking but now nothing just red led on or off
    I have checked cables and connections plus fuses on boards all seem ok
    any help appreciated ?
    Re: LG 42PQ6000 plasma
    Can you supply pictures of the boards and parts inside the set?
      Hi Tom
      hope these help
      board numbers are
      EAY59544701 power
      EAX57622801 control
      EAX57566202 av
      EAX57633801 zsus
      EAX57633701 ysus
      justin
        OK, have you checked that fuse in the middle of the power supply? Between the 2nd and 3rd heatsinks (from the bottom of this image: https://www.badcaps.net/forum/attach...3&d=1411502216)
          just rechecked the said fuses 1 white one and 2 with black stripe all check out fine
            OK, using your meter, check for the 5V and other voltages on the connector going to the main board (AV board.) If possible use the legend to indicate what each voltage you tested is, for example:
            AC DET - 5.0V
            STBY5V - 5.2V
            RL_ON - 0V
              Ok tom here we go
              1st test red led on AV board connected
              1 17v 0.00 2 17v 0.00
              3 GND 0.00 4 GND 0.00
              5 12v 0.01 6 12v 0.01
              7 GND 0.00 8 GND 0.00
              9 5v 0.06 10 5v 0.06
              11 5v 0.06 12 STBY 5v 5.15
              13 GND 0.00 14 GND 0.00
              15 NC 0.00 16 GND 0.00
              17 AC-DET 5.15 18 5v-DET 0.01
              19 V5-ON 0.00 20 RL-ON 0.00
              21 AUTO-GND 0.00 22 M5v-ON 0.13
              23 KEY-ON 0.01 24 STBY5v 5.15
              2nd test AV board disconnected (relays click twice, tcon board green led starts flashing)
              1 17v 17.17 2 17v 17.17
              5 12v 12.14 6 12v 12.14
              9 5v 5.15 10 5v 5.15
              11 5v 5.15 12 STBY5v 5.15
              17 AC-DET 5.14 18 5v-DET 5.13
              21 AUTO-ON 4.22 22 M5v-ON 0.00
              23 KEY-ON 4.68 24 STBY5v 5.14
              see what you think ?
              justin
                Hmm, looks like an AV board fault as it's not turning on the supplies - need to rule that out.
                Would you happen to have a pair of 100 to 470 ohm odd resistors? Through hole style?
                  i dont have any to hand
                  but i can pick up some of these "Metal Film 0.6W 220 Ohm Resistor" tomorrow
                  any good ?
                  whats the plan?
                    Yes, those will work. The plan is to jumper the power supply and turn it on. Then you can test if everything else works by engaging the self test on the panel. This will show if the main board is the fault.
                      ok i have the resistors
                      could you help me with the self test pls
                      ps i dont have the remote
                        Won't need a remote for this test, not right now at least.
                        Unplug TV power cable before starting.
                        Disconnect power board->main board connector, on the main board end.
                        Between V5-ON (probably VS-ON) and STBY5V connect a resistor.
                        Between RL-ON and STBY5V connect a resistor.
                        Between M5V-ON and STBY5V connect a resistor.
                        Now, when you plug the TV in you should get some clicks and then the Vs and Va supplies should come up to approx 200V & 60V each - do they?
                          Hi yes just done it
                          yes it worked as you said
                          clicked and Vs and Va come up at 197v and 60.5v
                            OK. Look at the screen closely, do you see a slight glow from it?
                              yes
                                Ok, can you post a closer photo of the control board, I need to be able to see the writing better.
                                  control board
                                    OK, just above and to the right of the "LGE PDP" writing there are two holes marked EXT AUTO GEN
                                    Take a piece of wire and jumper these together by hooking it through both holes.
                                    Unplug the top most connector (should go to the main board)
                                    Plug in the TV, do you see test patterns?
                                      hey Tom
                                      yes done that
                                      its scrolling through the test patterns nicely
                                        Good, that means you will have to replace the main A/V board, this is the board with the HDMI ports on it.
