Lenovo Y50-70 (not touch) - Screen LED Backlight
    Re: Lenovo Y50-70 (not touch) - Screen LED Backlight
    I'm not sure you're mesuring the right thing. You should be getting 19V on both side of that resistor. (or at least the top side if it is burnt). Anyway check its resistance, it should be 0. Next would be to check for a short to ground on the connector.
      I get 17kohm and 0v (testing gnd from the lcd connector)
        what voltage do you get at PC1135?
        when you got 19V from pin 16 of PU1101 did you got them right from the pin or before PR1115? The second is the correct thing to do.
          I got it right from the pin. Will check voltage on PC1135
          Thanks guys !
            Pc1135 gives 7v also... This is strange...
              This is strange indeed.
              Can you confirm if your board is just like the photo posted by piernov?
              The schematic shows that PC1135 is connected at 19V by PL1101, PL11050 & PL1106 but photo shows that is connected by the PU1102.
              Can you read the part number of PU1102?
                It does look the same, here is some pictures
                  Pu1102 is
                  97374m ti 47 apsf
                    ok, PU1102 is CSD97374Q4M [schematic has is wrong written!] which is a buck converter that lowers the voltage of Pc1135 for other circuit.
                    The issue is that we need 19V at Pc1135 so we need to find PL1101, PL1105 & PL1106 that supply them.
                    Can you also post a photo from the other side of the board?
                      I will put more pictures later on today, thanks !
                        So, here you go. Looks that jp11 is strange but for the rest nothing special...
                          ok, at the left I can see the three coils [PL1101, PL1105 & PL1106].
                          Measure the voltage at both of their sides.
                            7.32v on all of them... I checked the little u11 and seems that I get 3.16v on pin 2 and the rest 0v and all components next to it also 0v
                              The 3,16 V at u11 should be the pin 5 [pin 2 is ground]
                              also I'm guessing that pin 1 will give that voltage when system is running as you can see image at the display.
                              You said that coils all have 7,32V, one of their side is B+ which is the supplied voltage of your power supply after passing the two dc-in mosfets PQ301 & PQ302.
                              Take a measurment before PQ301 [pins 5-8] and after PQ302 [pins 5-8].
                              I want so see what voltage are you getting from your power supply and how much of that is feeded at the system [B+]
                                Pq301 pin5-8 get 0v (working on battery so probably normal)
                                Pq302 pin5-8 get 7.3v
                                  can you also try with a power adapter?
                                    Ok, with power adapter (battery disconnected), get 20.4V
                                    Measured R375 again, got 20.4v on first side and 0v on second, so I guess that this is wrong...
                                      ok, it's time to find a simillar size zero ohm resistor or a smd fuse [2,5 - 3A] and do a replacement
                                        I've that one from a dead motherboard (Packard bell), is this fine?
                                          Ok, I get 20v now but, still no light...
