bios dump elitebook 840 g3
    Re: 6050A2892401-MB-A01 BIOS please
    Originally posted by omruu9 View Post
    write let me know here brother thumbs up hope it will work for you
    Good day sir no response sir led power button just stays open , bench supply taking 15milliamp
      try this too
        Originally posted by peste View Post
        try this too
        I think my ec chip is dead it cant detect by the programmer (tl866 pro)
          Re: bios dump elitebook 840 g3
          This is my HP 840 G3 16mb bios dum..
          It starts with no display and fan spining
          also first 2long beep and 2short then 3long beep and 2 short...
            try..
              Thank you peste.. This bios works ... it was a cpu prob after reflow with this dump you send to me .. IT WORKS
                Hp 840 g3 6050a2728501-mb-a01 .
                PRODID L3C65AV
                  PRODID L3C65AV
                  post the original bios of the laptop ,,, backup ..
                    hello Friends
                    Have this board 6050A2892401-MB-A01 whith locked bios, would you give me a hand to unblock it please, i don't quite get it, on how to merge "the upper part with the lower part" of the file
                    Thank you in advance.
                    Best regards
                      Originally posted by alterr333 View Post
                      hello Friends
                      Best regards
                      the bios posted is longer..be careful when reading and writing the bios chip..try ..
                        Thank you my friend, its a 16mb chip i guess..
                        At 4am i ended up reading here: BADCAPS
                        About that HP Unlocker.exe
                        Draged the LOCKED bios to the executable, the exe made a UNLOCKED bin, flashed that back, and worked like a charm.
                        Thank you tough, for replying so fast.
                          This is locked file, can you please clear the password for me. Regards
                            try..
                              Hi guys, can anyboody help me out, I need to unlock BIOS password on a HP Elitebook G3. Or give me a hint how can I do it by my self.
                                here's the clue ...
                                https://www.badcaps.net/forum/showthread.php?t=79956
                                  HI guys.
                                  I think I screwed up my bios when trying to reprogram it, and i do not have the original bios anymore.
                                  Is there any way to copy a new bios on it? I tried some versions but all i get is black display and fan spinning on max.
                                  Thanks.
                                    check this
                                      try this no pass
                                        HP Elitebook 840 g3 hp dxe update error
                                        Bios update failed. This Pc restart loop the dxe update error. I can not find it dxe driver error.
                                        HP EliteBook 840 G3 6050A2892401-MB-A01
                                        Thanks for the help.
                                          Re: HP Elitebook 840 g3 hp dxe update error
                                          try..
