Lenovo ThinkVision T22
    I picked up this monitor which powers on, but has weird patterns on display.
    I noticed also some vertical lines on the far left so I dismantled the monitor and try to apply pressure on the panel ribbon.
    Then I noticed as I power on the monitor a "burn" light appears on the far left ribbon cable indicating a shot.
    I tested some caps and found a few ones shorted.
    The mainboard is definitely fine, as I checked with a working monitor and still the same issues.
    Any help what might be causing this and where to start?
    Re: Lenovo ThinkVision T22
    The short caps I meant on the panel board
