Unlock HP z840 Manufacturing Mode
    I need to unlock the HP z840 Manufacturing Mode to restore the TPM functionality of the motherboard.
    Is that possible?
    I have posted a thread on HP Support forum without success.
    https://h30434.www3.hp.com/t5/Busine...s/td-p/8103194
    Thank you.
    Re: Unlock HP z840 Manufacturing Mode
    Is that possible?
    Thank you.
    try this..
    https://www.youtube.com/watch?v=9T57ktw8n3Y
      this tool is the HP BIOS Configuration Utility (BCU)
      latest version can be downloaded here:
      http://ftp.ext.hp.com//pub/caps-soft...it/HP_BCU.html
      It gives me error when trying to unlock the MPM:
      <SETTING changeStatus="fail" name="Manufacturing Programming Mode" reason="SetBIOSSetting: Access Denied" returnCode="6">
      <OLDVALUE><![CDATA[Lock]]></OLDVALUE>
      <NEWVALUE><![CDATA[Unlock]]></NEWVALUE>
      </SETTING>
      <ERROR msg="Failed to set BIOS config" />
      <Warning msg="BCU return value" real="16" translated="16" />
      </BIOSCONFIG>Process Completed Successfully.....
      It will not unlock the MPM.
      Thank you for your feedback.
        I read this document:
        Instructions on CREATING the MPM-Unlocking SMC.BIN USB Drive
        https://manualzz.com/doc/44691860/in...ng-smc.bin-usb
        I tried using HP NBDmiFit tool
        https://www.finalfixer.com/2020/02/h...mifit-all.html
        But the included FSMC.bin that you rename as SMC.bin is not working on the z840.
        At least I followed the procedure described in the above pdf without success.
        Thanks.
          hi,
          I tried the UefiMpmUnlock.efi but i got "HP MPM protocol is not present."
          so what else I can do?
          Thank you.
