I have strange issue with one rear laptop Trekstor Primebook U13b.
The problem is that when i connect keyboard flat cable and on pwr button laptop turns on and after few sec it goes off.
I assume that is because i have 2v on pwr button pin (without cable connected) and when i connect the cable it drops on 0.3v so basically it detects that the button is pressed all the time.
Measuring resistance between pwr pin and ground pin on the keyboard cable i see there is around 50k without pressing the button.
Also trackpad is not working at all (it has separate cable).
In Windows (I'm able to boot in win if i don't connect keyboard) i see that two I2C drivers are with yellow exclamation sign (not working)
It uses IT8987E but im not sure is it problem related to the keyboard and trackpad or it is related to IT8987e because as i know pwr pin should be 3.3v.
Did someone have similar issue or some advice what to check or to try?
Thank you
Thank you
