measuring capacitor using Time Constant?
  • microfarad_the_2nd
    • Nov 2012
    • 4
    I remember Time Constant theory from my Electronics courses 30 years ago.
    I have been reading badcaps for a few days now.
    I'm not yet understanding much about ESR yet, but I do understand capacitance.
    This might be a really dumb question, but assuming a person had virtually NO money to spend on any new test equipment, for out of circuit capacitor testing, would a series resistor and a stopwatch (and good quality DMM) not be enough to make a "rough" measurement of a capacitor? I mean, using the 5 Time Constant principle?
    If the resistor is carefully chosen, and if it's value is measured using a high quality DMM, the RC circuit could be designed to be quite accurate, would it not? example, a relatively long RC circuit Time Constant could be made such that 5 TC's are about 2 or 3 minutes.
    , uh, I guess I just realized, this would only be good for DC current measurement and testing the cap using just DC charging current. Does testing capacitors in our computer power supplies require testing at high (relatively) frequencies? I notice many posts here at badcaps talk about 100khz testing.
    ? sorry if the questions are on the dumb side, just looking for a little guidance. I like finding cheap/free solutions to things....
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Re: measuring capacitor using Time Constant?
    I am aware about this rough testing method but it is used for high capacity caps above the 20MF were most digital meters does not reach.
    For small and regular caps this way of testing is not good enough in our times.
    There is no cheap/free solutions when you need accuracy and productivity.
    Few months back I watched an Youtube video, some one with an analog multimeter was trying
    to show that you can charge and discharge one capacitor at the Ohms range and see the needle moving when discharging.
    Yes one carefully chosen resistor it can slow down things, but this is for people who does not use a clock on their wrist.
      You'd actually be best using a single time constant, or 63.2%.
      5RC is nearly 99.3% charged, so very hard to tell apart from 6RC etc.
      But another good way is using a 555 timer. An astable oscillator will vary frequency with capacitance in a 1/x relationship. I know of some older multimeters using this circuit, before they moved to charge-integrate-discharge schemes under control from a processor or logic.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8694
        Most cap meters for caps > 1 microfarad use RC timeconstant to calculate capacitance. But it's not necessary to charge it completely, just need accurate time/voltage measurement.
        You can still build an oscillator with a 1millifarad capacitor but you'd be using fairly low value resistors to get it to oscillate at a reasonable frequency, and if it's low enough, the transistors driving them will become an issue, possibly frying them...
          That is why many older, cheap multimeters only had a capacitor range up to about 20~40uF.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8694
            Unfortunately the two multimeters I have, have this exact issue... Apparently they do make oscillators but with large resistances and thus make measuring large capacitors take excruciatingly long (plus cap leakage current becomes a factor.) One of them goes to 100uF but it takes forever to get a reading.
            My Sencore LC meter however appears to use RC timeconstant with a more appropriate resistance to combat leakage and does not completely charge the capacitor, making readings much faster. But it still "caps" out at 0.2F unfortunately...
            (The one thing that I do wonder is that the Sencore can measure leakage at different voltages and able to discharge them fairly quickly as well somehow. This means I could charge one of those input caps to 200V... that's a lot of charge on that capacitor...)
            • Kiriakos GR
              Banned
              • May 2012
              • 940
              • Greece
              This is why God created the modern LCR meters..
              No more .. feed them volts to see if they are blowing up.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8694
                yeah the sencore cannot measure ESR/ESL... but sometimes you have to charge it to the correct operating voltage to see what the real leakage is.
                Also it was designed to reform capacitors - though it's not a problem with most of today's electrolytics, older electrolytics needed to be reformed if they sit uncharged for too long.
                • Francesc V.
                  Technics SA-AX530 in protected mode. Overload message
                  by Francesc V.
                  I got a request from a friend of mine to have a look to his amplifier. When switching on "OVERLOAD" was displaying, however from time to time, message disappears and protection was removed.
                  I took some time in visual inspection (no bold caps, no solder joins, no burnt components neither hot burnt areas). I took some time to measure transistors and diodes. Everything seemed ok.
                  I realized that when OVERLOAD was on, pin 13 on IC601 (RSN307M44A-P) measured 5V. From time to time, when Amplifier was not protected pin 13 measured the right -1.5V
                  (Pin 13 goes through...
                  11-18-2024, 12:39 AM
                • titomno2
                  Gaming Laptop Zephyrus S17 TFT not detected every time !
                  by titomno2
                  Hi guys,
                  I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
                  So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
                  On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
                  Then the screen won't work for a long period of time.
                  If I wait 1 or 2 hours it work again most of the time.
                  When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
                  01-19-2025, 08:27 AM
                • Byte_76
                  Requesting assistance with 486 motherboard repair
                  by Byte_76
                  I have a seemingly rare 486 motherboard which shows no signs of life.
                  The Motherboard is marked with the labels B887 / 8 / 9 AI, which seems to be a Mecer branded board.
                  With an AT power supply hooked up, the power supply turns on but the board does not post, there is no beep and there is nothing displayed on the post analyser card, whether it's plugged into a PCI slot or an ISA slot.
                  I found a thread on Vogons of someone else who had the same board in working condition.
                  What I've tried so far: (In each case, the symptoms remain unchanged as...
                  04-12-2025, 06:43 AM
                • flat-earther
                  Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
                  by flat-earther
                  I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
                  To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
                  I have opened the camera and I think there is enough room to add something inside to accomplish this:
                  The camera is powered by a 3.7V nominal single cell lithium ion battery.
                  So I need to connect another battery in...
                  06-08-2025, 02:00 AM
                • cloo
                  Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                  by cloo
                  I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                  It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                  So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                  After doing a factory reset this problem was gone and the picture was back to...
                  01-06-2025, 06:02 AM
