Unlock asus for free
    WHAT YOUR HASH DATE
    ASUS BIOS PASSWORD UNLOCK
    ASUS laptops had almost same bios security which it rely on date , eg : 20121231
    to generate correct password we need the date displayed on your prompt screen.
    Re: Unlock asus for free
    pls just give me asap the 1st 3 dates when u see this. ill be waiting.
    eg. if u see this today give for 21 to 23 of this month year.
      Hi, I have a problem with the master password and k50in
      Date: 2009.08.06
      Help
        http://onns.ru/index.php?action=asuspwdgen&lang=eng
        they have a online password gen.
          is it free?
            try it and let us know
              just tried hp mini works I don't have asus to try
              here are some more free http://dogber1.blogspot.co.uk/2009/0...ered-bios.html
                had an Asus M51V with bios password.
                to reset it, remove the battery and boot it with just the AC power.
                when it says NVRAM check, unplug AC power.
                it will reset the non volatile memory in the bios.
                put battery back in, plug AC back and the password will be gone!
                  for doing that you must remove the Cmos bat as well or it will have no sucess ,
                    There was a list here for asus bios passwords from date
                      there is this, https://www.badcaps.net/forum/showth...us+series+2008
                      and this. https://www.badcaps.net/forum/showpo...87&postcount=7
                      and I think there may be more
                        Originally posted by trebo View Post
                        I've been searching for hours, the zip file you linked to is the closest I've come. The earliest my BIOS can go is 2012/01/01 due to a start-up password, so I can't get into the OS. Does anyone have the code? Or a link for dates in 2012?
                          Here is my list copied from some site I can't remember. The codes worked on an ASUS K50IJ laptop I repaired.
                          Mediafire
                            I try to unlock asus with this method (I found all years file with code ) on ux30 with no success.
                              Try this
                                Originally posted by jasko_jacker View Post
                                Try this
                                That's brill, thanks
                                  Below is the screenshot of the ASUS notebook I unlocked.
                                  Bios date is: 07/10/09 so I tried couple of codes and one worked, I don't remember which one.
                                  I first assumed it is the year/month/day like in TXT doc so the code for
                                  2007-10-09 is 1AAAABAB and it didn't worked
                                  Than i tried with month-day changed order
                                  2007-09-10 which is AA2LBADB and also that didn't work
                                  Than I tried with the year being the last 2 digits:
                                  2009-07-10 - L11A0ADB
                                  and again reversed month-day
                                  2009-10-07 - 000LAALD
                                  I got the code right from the third try but I don't remember the order I did.
                                  This is only to help all of the users here to check the other variants of codes if they didn't do already.
                                    is there a rescue password for asus x550ca 2016/6/19
                                      and is there a rescue password for asus x205TA 2012/01/13 ?
                                      Hope you will be able to help me guys :b
                                        Okay guys
                                        i finally solved my prob by changing the bios date, and then i used a password from the list, but i didn't thought that the french keyboard will be a prob x)
                                        so for azerty keyboards for 2002-01-02, press qlqq4qbq instead of alaa4aba
                                        hope it will help someone :b
