HP Elitebook 820 G2 bios needed
    Re: HP Elitebook 820 G2 bios needed
    Still the same issue with 1.29, 25Q128 in correct position.
    I plug the CH341A, then the detect works fine, and then ... no erasing or programming works. If I unplug/replug it works x1 time ... then redetect do not work a second time ...
    Do you have a link to the 1.29 release + driver you used to successfully program the 25Q128 ?
    Thanks !
      Thanks !
      Try it again, but this time:
      1.- Disable any antivirus (your app or the Windows defender)
      2.- Try to unzip again your Programmer app, on the first times I use it, one file is detected like virus, and my antivirus automatically disable it (without notification), so after antivirus and firewall disabled, the programmer run properly.
      I hop this works for you, otherwise, let me found how can I upload or find the source link where I download.
      Regards
        finally changing programer I was able to manage the Winbond chipset.
        I successfully flashed EC+BIOS.bin on a 840 G2 (somebody kindly proposed here the 2 fulldump files)
        But I've an issue as the Elitebook start in MPM mode (Ok), but then detect issue "not in commited state", reset the bios and restore a config ... and I lost the MPM mode not able to get it back and use wmdmifit tool to enter UUID, SKU etc.
        Does somebody successfully recover MPM mode to configure an Elitebook ?
        Thanks !
          Hello Satdream,
          I have a 840 G2 with bios password, and also have a ch341a programmer.
          I was wondering:
          you used a different hardware or software? And what hardware /software you used?
          Are those the files at post #4 of this topic?
          https://www.badcaps.net/forum/showpo...79&postcount=4
          But I've an issue as the Elitebook start in MPM mode (Ok), but then detect issue "not in commited state", ...
          after this warning, you reset the laptop (10 times) before booting to windows so you could use winmifit to alter sku/ serial etc..?
          hope you can help me out,
          with regards,
          Peben
            I finally ordered another SPI programmer (EZP2013) as with the CH341 I never successfully programmed the Windbond Q128.
            Yes
            No, after the warning, it was not possible to boot before the bios restored configuration (network etc.) and then the MPM mode was disabled before being able to boot WinME and run winmifit etc.
            Finally I got another Bios (here also) of 820 G2 (fully compatible with 840 G2), from somebody asked to clear password ... flashing with bios I got a fully workable laptop (no warning message etc.) BUT, I got also the SKU/Serial of the PC the Bios come from ... and not mine ...
            In any case for me the CH341 never worked for the main Bios chip, I tried several release of the software but once detected, then error to communicate ...)
            Hope this help
              Re: HP Elitebook 850 G2 bios admin pwd help
              Hello Rioreno,
              Originally posted by rioreno View Post
              -for programmer depending your budget, but if you dont have issue for budget , better you check for svod programmer...
              http://www.svod.od.ua/124-programmer-kb9012
              this svod programmer can be used for programming bios chips without desoldering it?
              regards,
              Peben
                Hello Rioreno,
                regards,
                Peben
                I think this tool can used programming chip without desolder, you can use soicclip as a tool..
                  Can someone please help me?
                  I have a 820 g2 with no original bios dump and the post image appears after 20 seconds. I tried all dumps in this topic.
                  My laptop series are:
                  SN: 5CG53413XH
                  SKU: F6N29AV
                  PCID: A3009D510303
                  In Uefi tool i get the following errors:
                  Manny Thanks for anny solutions!
                    SN: 5CG53413XH
                    SKU: F6N29AV
                    PCID: A3009D510303
                    The bios provided by RIORENO Page 4 is working and allow to boot and work reuglarly with correct SN/SKU etc. BUT you'll not be able to change them ...
                    try this..goodluck
                      I tried this dump too, still 20 second until post image
                        try this
                          Originally posted by dycc View Post
                          try this
                          This works perfect, THANK YOU!!!
                            Hi DYCC
                            Can you explain what it means ME clear?
                            I have dump from post 4 in my elitebook too.
                            thx
                              Originally posted by fifthy52 View Post
                              Hi DYCC
                              thx
                              it mean add the original intel management engine release by INTEL into the bin file
                                urgent need bios bin file 840 g2 plz help me out its very urgent thanks,
                                  Here
                                  first of all thank you for your effort and does this bios work fine without password
                                  because i have hp 840 g2 with locked bios
                                  please tell me
                                  thank you
                                    hello, try this, if need to change sn, board id, use wndmifit or hpbcu..
                                    thanks its work
                                      Here
                                      can you unlock this for me
                                      beacaus i had a problem after reflashing 840 g2 bios that you uploded
                                      machine is not in commited state
                                      and still about 15 sec to appear post logo
                                      it'm may be because there is invalid sn or system board ct number
                                      please help me
                                      thank in advance
                                        please help me
                                        thank in advance
                                        Try this..
                                        goodluck and please confirm..
                                          Try this..
                                          a hundreds of thanks for you
                                          it's worked correctly
                                          But i have the same problem with my lenovo l540
                                          it's take about 18 sec to appear post logo i tried a lot of bios dump but still the same problem can you help me with it
                                          thanks in advance
