new style led tester
    Just saw this on ali express so it looks like it powers the leds and tests the amps? would this show us shorted leds easier
    https://ru.aliexpress.com/item/AC-22...3-2e39c91e7e13
    Re: new style led tester
    This looks good but the labels are in...is that Chinese??
      yes i think it is chinese ive been looking for a user manual but cant find one theres no videos on youtube either of this unit in action.
        I'll see what I can find...
          just wondered if it was better than the type shopjimmy sell as this one seems too tell the amps too so wondered if that would suggest a shorted led etc
            the one from shop jimmy works great. shows shorted led and is automatic.
            SID GJ2C LED TV Backlight Tester
            http://www.shopjimmy.com/sid-gj2c-le...ght-tester.htm
              Yes. I have the GJ2C also and found backlight troubleshooting very easy with it. I also have a CCFL backlight tester and I am using it a lot these days as there are a lot of CCFL/EEFL backlights failing now......I have successfully converted LCD TVs to LED TVs....well 5 of them so far as some customers prefer to just get a new TV.
                Looks nice for you 220v guys. Looks adjustable although I can't read Chinese or russian
                  Notes from web site:
                  0-180 V Output LED Backlight LED Tester LCD TV LED backlighti Tester Lamp beads Light light board Tester FREE SHIPPING
                  multi-adjustable LED lamp repair tester
                  Operating Voltage: AC 180V-240V ( not international)
                  output voltage (withstand voltage): 0-180 In
                  1. Adjustable output voltage, output current. ( Please change the test current voltage because there is no soft start protection technology.
                  instant large current may cause a malfunction of your lamp
                  2. Adjustable brightness lamp beads.
                  3. Medalions leak detection.
                  4. Two high-precision meter reading data, high precision.
                  5. Automatic adaptation of control lamp beads / lamp voltage panel.
                  6. The voice prompts lamp beads without seeing and increase efficiency.
                  7. Electrical insulation safer, touch one end of the power is not a man. (Note: do not touch the positive and negative ends at the same time)
                  8 can be detected below 180 V LED voltage.
                  multi-adjustable LED lamp beads service tester tests and operation of the LED lamp beads equipment. specially designed for the majority of electronic enthusiasts. lamp beads to solve caused during assembly does not shine the light does not cause any problems. you can quickly identify problems that lamp beads. thus effectively improve service efficiency and save maintenance time, reduce indirect labor costs.
                  the operation is very convenient and simple, red pen and a black pen alignment plate or lamp beads can detect positive and negative, the normal lamp beads Lights. when the two faced pen, forming the path of light.
                  Output current range: 0 ~ 20mA
                  Package includes:
                  1 PC. tester
                  2 pcs. test pen (Black and Red)
                  1 PC. LED panel light transmission cable
                  1 PC. EU plug power adapter
                    Package includes:
                    1 PC. tester
                    Thanks budm for that information would you use one of these? or prefer the shopjimmy model they sell as it automatically does the soft start voltage etc.
                      I would use the one with soft start. You can get the same tester that SJ sells from Amazon too.
                        Thanks i will order one asap as its a handy tool to have.
