Hp pavilion dv 7 with no power
    please I have this HP pavilion dv 7 laptop, power jack LED doesn't on when you put in the charger and after checking the board i only get 19v under 8 pin ic closer to the power socket,please if anyone can help me solve this problem i will be grateful.
    Re: Hp pavilion dv 7 with no power
    these is the picture of the motherboard with the said ic that what my finger is pointing at
      any 5v, 3v? if not check charger. please provide more information
        mobo number JBK00 LA-4092P Rev:1.0,please really need help
          check pu101 (bq2474) pin 2 . what voltage is there?
            charger gives me 19v and 3.3v but when i plug it in the power jack I get only 19v and no 3.3v
              tell me what voltage u get on PL102 with and without battery. it shoul be 12v with battery and 3v without battery
                I don't get any voltage when I put charger or battery at PL102
                  do you have a linear lab power supply? if yes just set it to 19v, 5 amps and probably your charger will get verry hot. if yes, change the charger. your problem is there or in output fets
                    Make sure that you use original charger i have had where the universal did not work
                    have a look at page 45
                      the charger am using is 18.5v - 6.5A
                        Is it the original ?
                        in the passed i have had no power/led/charger led off/
                        and has been the charger
                        http://wiki.robotz.com/index.php/HP_Smart_Pin
                          please I have changed the charger but still same problem,please am really not good in reading the diagram but if you show me how to I can learn it,please help me
                            i undertstand you but you must know at least basics....
                              thanks very much,I have been able to locate the spoilt ic
                                Have a look at some video's
                                https://www.youtube.com/watch?v=BrsZGFCIqrY
                                  thanks very much cyberhack,will like to have your email
                                    cyberhack I really want to learn a lot from you,will be grateful to be your friend
