Hp DV7-6151EF only turns ON every 30 atempts
    Never see something like this.
    Oncee i get it running it works perfectly, can reboot withou a problem.
    Once i turn it Off, here the problem:
    When i press the On Switch, there is no led or any reaction, when i have a battery inserted, and running only on battery, when i turn it of, the led near the power imput connector it stays ON (WIERD)
    Model : Hp DV7-6151EF
    Any Clues Guys ?
    Re: Hp DV7-6151EF only turns ON every 30 atempts
    may be static electricity.
      It makes the same wierd sympton on the owners house and on my local ?
      Can you develop ?
        If the laptop turns on after a number of pressing the power button, it may be due to static electricity.
        it is just a possibility.
          Check cmos battery check.
          Try running the laptop with cmos battery out ?
            Actual Cmos Battery is reading 3,02V, i have replaced with another reading 3,01 and Laptop is now turning On Normaly.
            Very Wierd.
            Anyway, thanks guys for your Tips.
