sony vaio works only on battery
    As per topic I have sony laptop having mobo mbx-268. It works on battery only , when adapter is plugged it shutsdown down instantly. No Charging, no power.
    No shorting found.
    Changed charger IC.
    Can anybody help me to short out.
    Thanks in advance.
    Re: sony vaio works only on battery
    Hi
    How is the voltage on PR265 when plugged in the Charger without Battery
      Have a look at this
        get a multitester, try to test the output voltage of your power adapter if it has enough power , like, 19vdc or 20vdc..
        ( (IT Technical Support)
