Another LG, 55ln5100 power issues
    Re: Another LG, 55ln5100 power issues
    Originally posted by Redrebel10 View Post
    I inspected everything under the psb and all looked good. What are the 2 3.5volt pins for? meaning are they responsible for sending power to the mainboard and it triggers all the other voltages?
    https://www.badcaps.net/forum/attach...2&d=1579659498
    The 3.5V pins are the 3.5V standby power supply so the Voltage should always be present.
    The exposed pins you see on the top side of the board are for the ODD number pins.
    You count the pins correctly?
      Originally posted by nomoresonys View Post
      Did you check all the diodes on powerboard? just check m in diode mode, should get a reading in one direction usually .2~.7 or so then reverse the test leads and should read OL, simple diode testing there: https://www.youtube.com/watch?v=mMXDa5hVzXA
      Thanks I'll try that when I get home
        If any diodes read off, lift a leg out of circuit and test again.
          Budm. Since losing the standby light and can no longer get the backlights on, I can only get 2 readings on your psb connector and that is both of the 3.5 pins.(top pins)
            I was going to ask if I needed to take it out of circuit diode, D201 reads the exact same if I flip your neg and positive leads
              That means the 3.5V Standby power supply is OK, the main board uses that 3.5V to run, when power switch is activated then the main board will send all the needed control signals to turn on the rest of the power supply, so at this point you have problem with the main board due to the fact that you do not even get the standby lights to be on when the main board has 3.5V to run.
                D201 is for the 3.5V standby power supply, if it is bad you will not be getting the 3.5V.
                What are the EXACT readings showing on your meter?
                https://www.shopjimmy.com/lg-eay6281...upply-unit.htm
                  Yep, take it out of circuit, if it reads the same I would replace it.
                    Like. 27 on that one but if that controls the standby voltage I guess it's good since I can still get 3.5v on those 2 pins. Gonna try heating up the main board and see if that does anything, have the new eeprom coming in Friday, the main board replacement is 60 so hoping I can find a cheaper fix
                      It is rectifier diode for the 3.5V power supply, if it conducts both direction then the output will not be DC any more.
                      0.27 Ohms in both directions? Did you test it in Ohm mode? I do not think you have bad diode otherwise there will be no 3.5VDC on the output.
                        OK thanks, yes I tested in diode mode same mode I would test a fuse for continuity. So at this stage are you thinking the fix would be replacing the main board?
                          lg tv mainboards seem too suffer from bga solder issues some people use a proper reball set up some people do a reflow using either a heat gun or a lamp etc various methods on youtube this is one thread on this forum
                          https://www.badcaps.net/forum/showthread.php?t=55409
                            Test in diode mode will not show result in Ohm, it will show in Volt. Use Ohm mode to test fuse since bad fuse can have high resistance more than 10 Ohms so it will still show as conducting which will lead you to believe that the fuse is good when using diode mode to test the fuse.
                            You have main board problem as I indicated before due to the fact that you do not even have LED indicator.
                              +1
                              While you're waiting on the eeprom, why don't you run a couple of tests to make sure that the PSB and LEDs are good. See attached diagrams.
                              Edit: Once you have the resistor jumpers in the connector, put something like cardboard down, so that if you lay the connector down, the resistors do not short on the chassis or main board.
                                Thank you to all helping, I will update tomorrow after getting new eeprom and I will try all that is suggested
                                  Well tried the new eeprom (no change) and tried baking the main board for 10 minutes at 385 degrees and still no change. So it looks like I buy a new main board or trash the TV
                                    Looks like it's getting pretty expensive, I would start keeping it indoors if you get it fixed.
                                      Lead free solder melts around 422F. You weren't hot enough.
                                        Before you toss that main board, do you want to check some of the required voltages?
                                        I'm including the SM for a 47LN54**. The main board in that set is also used in the 55LN5400. I believe the only difference in the "5100" is that it doesn't have the SmartShare option.
                                          Sorry I already ordered a new main board before you posted that
