Asus X455LJ REV 3.1 working BIOS dump needed
    hi
    anyone who have it pls help
    thanks
    unit no display
    Re: Asus X455LJ REV 3.1 working BIOS dump needed
    Try this one
      Thanks. I tried it and it's working.
      What I notice with this laptop is when i plug the charger without battery the laptop power on itself. (is that bad?)
      Then it will work the whole day. The following morning when i try to power it on, same thing happen won't come and I only see charging light.
      When I try to press pw sw it will standbyoff screen , then press it twice the display comes out again.. so i think power switch is working.
        Bios ASUS X455LJ KB9018 ECROM please master
          Originally posted by cacla View Post
          Try this one
          Thank u very much...!!!!!
          It's work on Asus X455LJ Rev. 3.1
          U save my day bro....
            thank you for sharing
              CACLA Thanks to you ..........This x455lj bios is okkkkkkkkkkkkk...Thanks Again for Upload
                tested... thanks for the file... really works
                  very nice.....
                    I have a problem to program this BIOS, when it ends it throws the following error, some have had that experience can help me, I am using miPro tl80, the chip is the 25B64CSIG in the programmer's library only the GD25Q64B reference appears to me from the manufacturer GigaDevice
                      Untick "STATUS REG.". For 25B64CSIG, the GD25B64C model should be selected.
                        Update your software,Version 6.71 added support for the GD25B64
                        http://www.autoelectric.cn/MiniPro/minipro_setup685.rar
                        http://www.autoelectric.cn/en/tl866_main.html
                        Version: V6.71 Support:14299 --2018.04.17
                        ADD:
                        PM25LQ512 /010/020/040/080/016/032 GD25B32 /GD25B64
                        Fix: S24S45 DS1220(RW)Algorithm.
                          thx sooooo much its working the programmer whitout problem the laptop continue whit the proble but thx
                            Thanks Cacla...
                              Thanks bro ..
                                thank you!!!
                                  thank you working for me..
                                    Try this one
                                    terima kasih kawan
                                      thanks cacla its work
                                        Try this one
                                        thanks for the dump files...
                                        Never stop LEARNING because life never stops TEACHING!
