Hitachi 50HYT62U no picture
    Hitachi 50HYT62U, has backlights but no picture, just completely blank screen, any ideas anyone??
    Re: Hitachi 50HYT62U no picture
    See if you have about 12 volts on each side of the fuse on tcon board.
      12.08v on each side
        Try unplugging the wifi module, check for any change.
          Tried that, no change.
          Also tried holding power button for 60 seconds, plugging in tv, and continuing to hold a further 60 seconds
            Any chips on the tcon or mainboard getting really hot?
              What do you get on the screen if you only have one ribbon cable between LCD panel and the T-CON connected one at a time?
                If I unplug the left ribbon, I get no change.
                If I unplug the right ribbon, I get the attached pic
                  Just hoping its not the LCD panel thats at fault :/
                    Guess you could test your caps on the driver board for shorts or very low ohms.
                      The LCD panel has integrated T-CON board and also located at the bottom edge of the LCD panel which is easily damaged by the cleaning liquid, so inspect the T-CON/Tab bonding board for damages and also check the caps resistance as suggested.
                        Doesnt appear to be any damage to anything. Which baord is the driver board??
                          "Doesnt appear to be any damage to anything. Which board is the driver board??"
                          So you remove the LCD frame to get to the T-CON/Tab bonding boards?
                            Yes, Ive had the screen out n checked the backlights whilst I was on
                              Show us the pictures of the boards that are connected to the LCD panel..
                                Hope these help as hard to fit all in pic with being long
                                  Yep those are the driver boards.
                                    Great, so which bits do you need ohm readings from?
                                      There are many caps on those boards, you have done them before in other threads, did you not?
                                        No, I have never done anything with these boards before
