Plasma Panasonic TC-P42C2
  • Fripacks
    • Jun 2021
    • 59
    Hi guys,
    Hi, I have Panasonic model TC-P42C2 with Blinking led on the front, I found this TNPA5066AC SN Board defect, now the TV working with the new board but picture is very weak with blue color predominant and some horizontal lines, I check all the flat wires connections on the board and they ok, could you tell me if it's the new Board can cause this or the plasma panel is defect?
  • kasfamily
    • Aug 2014
    • 765
    • Russia
    Re: Plasma Panasonic
    Show a photo of the image on the screen
    • Biruslapio
      • Nov 2013
      • 552
      • Brasil
      Wrong variant of the board? If your original board was for example TNPA5066AB and you replaced with AC the voltages are tuned differently and will change how the plasma panel operates, causing these picture issues.
      • Fripacks
        • Jun 2021
        • 59
        Re: Plasma Panasonic TC-P42C2
        The original board is TNPA5066AD, the new board is TNPA5066AC, do I have some adjustements to make?
        • Biruslapio
          • Nov 2013
          • 552
          • Brasil
          Yes, that will require magnifying lens, hot air and patience, you have to compare the two boards side by side and check every component, some of them are different.
          Or you can look at this .pdf, it contains only the SN schematic, and search "*", all components marked with * varies between suffix revisions (AC, AD etc), then look at said component in both boards and add, remove or swap them.
          If you cannot or do not want to do that, then using an AD variant is the only option.
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
            by sam_sam_sam
            After all of...
            07-13-2024, 08:14 PM
          • canadaboy25
            Panasonic TC-P54VT25 No image. A or D board?
            by canadaboy25
            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
            The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
            01-17-2021, 01:06 AM
