Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 06-01-2022, 12:43 PM   #1
Rmasters3
Default 55G310U Toshiba Dead
Can't get anything out of it. Power supply outputs all ) as well. The obvious answer is Power Supply Board unless it needs to be switched on by the Main Board. Suggestions?
Thanksl
Rmasters3 is offline   Reply With Quote
Old 06-01-2022, 01:14 PM   #2
neilc6
City & State: BC
My Country: Canada
I'm a: Knowledge Seeker
Default Re: 55G310U Toshiba Dead
Power supply typically supplies standby voltage to the main board. When the TV is turned on, processor will send a power supply on to fully turn on ps and backlight on signal. If you have no standby voltage, power supply is suspect. Should be a main AC fuse you can check but fuses will blow due to shorted components.
neilc6 is online now   Reply With Quote
Old 06-02-2022, 02:36 AM   #3
Rmasters3
PS fuse checked OK, and with no standby voltage, I was assuming a PS problem. Thanks for the confirmation.
Old 06-02-2022, 09:35 AM   #4
dskall
dskall's Avatar
City & State: Bakersfield ca.
My Country: usa
Line Voltage: 120VAC 60Hz
What is your voltage across main capacitor?
__________________
dskall is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
