Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Thread Tools Display Modes
Old 05-21-2022, 02:51 AM   #1
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I'm a: Knowledge Seeker
Default Are these devices any good ( 5" TFT LCD Monitor Reversing Truck 4Pin Camera feed back
I think about buying one are these devices worth the money
https://www.ebay.com/itm/36364762849...3ABFBMjKuF3Zxg
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 05-21-2022, 03:50 AM   #2
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
Default Re: Are these devices any good ( 5" TFT LCD Monitor Reversing Truck 4Pin Camera feed
I guess they are cheap enough. Some of the cheap cams, the clear plastic rots fast.
CapLeaker is offline   Reply With Quote
Old 05-21-2022, 06:56 AM   #3
sam_sam_sam
My Country: USA
Quote:
That just great …—>
…—>are the more expensive ones any better than this because if not then I will look for the cheapest one that I can find
I really more interested in the monitor than anything else are they any good or are poor quality as well and are the more expensive ones any better
Old 05-21-2022, 02:42 PM   #4
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
UV will kill most plastic very fast.
if you can put it behind glass then most UVB/C will be blocked
stj is offline   Reply With Quote
Old 05-21-2022, 05:50 PM   #5
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
Quote:
Originally Posted by sam_sam_sam View Post
That just great >
To be honest, Id look for something else, as the specs dont rock my socks.
Old 05-21-2022, 06:44 PM   #6
sam_sam_sam
My Country: USA
Old 05-21-2022, 09:21 PM   #7
redwire
City & State: Alberta
My Country: Canada
There's many different cameras out now i.e. https://www.ebay.com/itm/363081107479
I use the smaller $5 camera like this (with parking lines) and it's very good https://www.ebay.com/itm/114262648935 small easy to mount, metal case and no need for IR LED's, it does fine at night.
redwire is offline   Reply With Quote
Old 05-22-2022, 06:36 AM   #8
sam_sam_sam
My Country: USA
Can you recommend a monitor that is decent quality that is what I am also looking for thanks
Old 05-22-2022, 08:04 PM   #9
redwire
My Country: Canada
I'm using the NAV's screen, have not tried any 5" mini monitors. 7" are about the same price. They seem to be 640x480 or 720x1280 or 800x480 resolution.
Tons of fake specs i.e IPS, 30 million pixels or 1080HD etc. Most of the time the spec is just left out of the ad.
The cameras are typically 1/4" VGA 640x480 0.3MP with analog video output. There are some with WiFi so you could use your phone/tablet as the screen.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
