Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices
Old 09-24-2021, 02:16 PM   #1
electrocute
City & State: madrid
My Country: spain
Default Lenovo Ideapad 330S-14IKB Not Powering On
Lenovo Ideapad 330S-14IKB Model: 81F4
Motherboard: 330S_KBL_MB_V09 Rev: MP (PN: 431204237090) (5B20S69494)
Has been working till now for two months after cleaning water damage.
Problem: does not power on. No consumption.
19-20V present.
3.3V and 5V not present.
No power around EC.
Missing ILIM, ACOK... on the charger. No EN nor PGOOD on the 3/5V power supplies.
Charger BQ24780SRUYT (U5901):
<1>ACN: 19.78V
<2>ACP: 19.78V
<3>CMSRC: 19.68V
<4>ACDRV: 24.6V
<5>ACOK: 0.01V
<6>ACDET: 2.36V
<7>IADP: 0V
<8>IDCHG: 0V
<9>PMON: 0V
<10>PROCHOT/: 0.26V
<11>SDA: 0.01V
<12>SCL: 0.01V
<13>CMPIN: 0V
<14>CMPOUT: NC
<15>BATPRES/: 0V
<16>TB_STAT/: 0.01V
<17>BATSRC: 0.22V
<18>BATDRV: 0.24V
<19>SRN: 0.22V
<20>SRP: 0.22V
<21>ILIM: 0V-0.003V
<22>GND: 0V
<23>LODRV: 0V
<24>REGN: 5.95V
<25>BTST: 5.62V
<26>HIDRV: 0.21V
<27>PHASE: 0.22V
<28>VCC: 19.51V
+V5P0A power supply (U6001):
<1>BOOT: 0.005V
<2>LX1: 0.018V
<3>LX2: 0.018V
<4>PGND: 0V
<5>VIN: 19.80V
<6>EN: 0.016V
<7>PGOOD: 0.017V
<8>AGND: 0V
<9>VCC: 0.017V
<10>VOUT: 0.017V
<11>LDO: 0.010V
<12>CLK: 0.014V
+V3P3A power supply (U6002):
<1>BOOT : 0V
<2>LX1 : 0V
<3>LX2 : 0V
<4>PGND : 0V
<5>VIN : 19.79V
<6>EN : 0.009V
<7>PGOOD: 0V
<8>AGND : 0V
<9>VCC : 0V
<10>VOUT: 0V
<11>BYP : 0.018V
<12>ILMT: 0.021V
I don't have the schematic/boardview for the exact model but for a similar one: schematic, boardview.
Any pointers where to start? Bear in mind I'm a novice.
electrocute is offline   Reply With Quote
Old 09-24-2021, 03:09 PM   #2
mon2
mon2's Avatar
City & State: Windsor, Ontario
My Country: Canada
Line Voltage: 110VAC
Default Re: Lenovo Ideapad 330S-14IKB Not Powering On
Hi.
1) U6001, LDO should supply @ +3v3 rail = always ON and is not linked to the EN pin # 6 as this is the "C" version of the switching regulator.
2) Remove all power - meter in resistance mode. Check the resistance to ground on each and every coil. Looking for super low resistance readings which may offer a clue on what is going on for this board.
3) Any new liquid damage ? Perhaps consider to flux and reflow U6001.
The +V3.3AL on pin # 6 is required to support many key components on the logic board including I2C bus and other pull-ups, power the EC, etc.
mon2 is offline   Reply With Quote
Old 09-24-2021, 03:29 PM   #3
electrocute
My Country: spain
Thanks for the prompt reply.
2)
Here are the measurements (same order as in screenshot/boardview, from left to right, top to bottom)
L6300: 0V 35.1 Ω
L6703: 0V 12.8 Ω
L6701: 0V 4.7 Ω
L6704: 0V 4.7 Ω
L6702: 0V 6.7 Ω
L5901: out of scale (showing 1. on 20MΩ scale)
L6001: 0.017V 20.3 Ω
L6002: 0V 7.92 kΩ and raising up
L6100: 0V 120 Ω
Using a manual range DMM.
3) no new liquid damaged reported or observed. Will try to reflow U6001 on monday.
Old 09-24-2021, 03:55 PM   #4
mon2
mon2's Avatar
My Country: Canada
Coil readings look ok. Low voltage rails will have low resistance values.
Power down and check the resistance of each mosfet starting with Q5901 & Q5902. Often one of these bad boys get nuked to halt the party.
ACOK = logic LOW = power good indicator. However, this open-drain pin will only present a HIGH if the +V3.3AL (+V3P3A_EC) is working which it is not...
Old 09-24-2021, 10:48 PM   #5
mcplslg123
City & State: siliguri
My Country: india
Line Voltage: 220vac,60hz
@mon2, coil readings dont look good to me. L6001 is for +5V rail and resistance is 20.3 Ohms. Clearly shorted. Seems like you missed it.
mcplslg123 is offline   Reply With Quote
Old 09-25-2021, 08:11 AM   #6
mon2
mon2's Avatar
My Country: Canada
Yes! Thanks for the correction.
1) Remove R10860.
2) Remove all power. Meter in resistance mode. Check and post the resistance to ground on R10860, each SMD pad. We wish to check where the short resides - is it on the side that creates this voltage rail OR the side that consumes this voltage rail?
It is quite possible that U6001 (RT6228CGQUF) may need to be replaced due to this event.
Good idea to grab a few of these for the toolbox. The "C" suffix is very important on this component.
Datasheet is attached.
https://www.aliexpress.com/wholesale...psort=1&page=1
Old 09-25-2021, 11:46 AM   #7
electrocute
My Country: spain
R10860 = solder blow.
14 Ω on the side of the +V5 power supply. (so short on this side)
1.55 MΩ on the +V5CP side.
Old 09-25-2021, 12:25 PM   #8
mon2
mon2's Avatar
My Country: Canada
Yes indeed.
See attached. Lift up one side of L6001. Then check the resistance again -> still 14 ohms ?
If yes, then it is down to the highlighted caps in the box.
Consider to remove each of the caps from the logic board and test the resistance again.
If you wish, you can certainly remove one cap at a time -> check the resistance -> repeat if required.
Suspecting it is one of the 22uf caps but you can also remove the 0.1uf.
Edit: C6014 & C6015 = NI = Not installed (?) so the cap check list is even shorter...
Old 09-25-2021, 12:45 PM   #9
electrocute
My Country: spain
Thanks. Will try on monday.
Yes, there are no components on those, only the pads.
Old 09-25-2021, 03:18 PM   #10
electrocute
My Country: spain
solder blob!
Old 09-27-2021, 06:43 AM   #11
electrocute
My Country: spain
Same after lifting up one side of L6001 and after removing the caps. That leaves pin 10 (VOUT) on U6001 so the 5V power supply seems bad, at least, and needs to be replaced.
Old 09-27-2021, 09:37 AM   #12
mon2
mon2's Avatar
My Country: Canada
Yes, if the external caps have been ruled out then through process of elimination, U6001 needs to be replaced.
If there is any doubt, consider to flux & reflow u6001 to make it 'dance' for good solder joints. Check the resistance again but sounds like this regulator is damaged. Best to order some spares in case this issue repeats.
Old 09-27-2021, 10:16 AM   #13
electrocute
My Country: spain
Is there anything else to check at this point (without having the replacement part) to rule out other problems on the board?
Old 09-27-2021, 02:39 PM   #14
Sephir0th
Sephir0th's Avatar
City & State: Wangerland
My Country: Deutschland
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
It's the Controller 99,99%. Replace it. Everything Else Looks fine now.
Sephir0th is offline   Reply With Quote
